Author Topic: aquastat  (Read 5333 times)
new builder
  • OWF Brand: cox stove company
  • OWF Model: Jc-1
aquastat
« on: July 01, 2013, 12:42:29 PM »
What's the best bang for the buck on a aquastat on a homemade unit ? Where's best place to get one from ?
Re: aquastat
« Reply #1 on: July 01, 2013, 01:56:36 PM »
johnson A-419, available in either 24 or 120 volt, digital display, accurate to within 1 degree, normally open and normally closed terminals, available anywhere plumbing and heating is sold, around 65 dollars, HOWS THAT
Re: aquastat
« Reply #2 on: July 01, 2013, 04:14:33 PM »
Also check out Ranco.  There great
new builder
  • OWF Model: Jc-1
Re: aquastat
« Reply #3 on: July 01, 2013, 07:28:24 PM »
The Johnson is exactly what I was looking for thanks !! Now what kind of thrermowell do I need for that ?
Re: aquastat
« Reply #4 on: July 02, 2013, 04:23:53 AM »
You may use a brass well if you wish but most manufacturers simply weld a well ( I think 3/8 tube steel ) to the side of the water jacket, this means less holes, less chances for leaks, silicone the ends and connect the leads. Oh  I almost forgot you can also use it as a hard wired monitor or control with thermostat wire up to 500 feet away from the probe
