Author Topic: Grundfos Circulator UPS26-99FC 3-Speed 115v  (Read 7883 times)
Homerglide
  • OWF Brand: Orlan EKO
  • OWF Model: Out in the shop - Model 25 gasifier
« on: August 10, 2013, 12:39:50 PM »
Here for sale is a a 26-99 3-speed 115 volt for sale. Just got it and find that it pushes too much for this situation. So it was used for maybe 15 minutes.
http://www.pexsupply.com/Grundfos-52722512-UPS26-99FC-3-Speed-Circulator-Pump-1-6-HP-115-volt-5587000-p
$200 delivered to your door
« Last Edit: August 11, 2013, 06:24:25 AM by Homerglide »
Coupla Chainsaws
Axe
Strong OLD Back
2000 Dodge Cummins
Re: Grundfos Circulator UPS26-99FC 3-Speed 115v
« Reply #1 on: August 14, 2013, 02:43:08 PM »
Why don't you just run it on a lower speed?
Homerglide
« Reply #2 on: August 15, 2013, 08:37:15 AM »
Yeah, low speed is too much also. The purpose of the circulator is to charge the stotrage tanks of a closed system. Originally went with a 15-58 but it would not keep up with the boiler output. Tried the 26-99 and even on low the boiler couldn't keep up with the flow. Finally found the sweet spot with a Grundfos 15-100. Boiler out temp is steady at 190-195 out without a hickup.
Anyway the Grundfos 26-99 3-speed may very well fit an OWB open system. See pump curve at:
http://www.intermountainsales.net/files/SuperBrute%20Family%20Curves.pdf
Coupla Chainsaws
Axe
Strong OLD Back
2000 Dodge Cummins
Homerglide
« Reply #3 on: December 30, 2013, 10:12:09 AM »
Bump
Coupla Chainsaws
Axe
Strong OLD Back
2000 Dodge Cummins
