Author Topic: Replacement pump  (Read 14340 times)
automan77
  • OWF Brand: ridgewood
  • OWF Model: 6000
  • Just say no to propane
Replacement pump
« on: September 10, 2013, 05:36:42 PM »
I have a Bell & Gossett nrf 36 and want to buy a backup pump that would be comparable with the 36.  I really don't want to spend 300 bucks. would the Taco brand have a pump that would be comparable with the bell & Gossett 36 that would fit my hookup.  I run 1 inch pex.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
Chas
  • OWF Brand: Ridgewood
  • OWF Model: 6000
Re: Replacement pump
« Reply #1 on: September 10, 2013, 05:59:59 PM »
Hey Scott
I have the Bell and Gosset nrf-25  3 speed pushing 180 ft from my basement back to the boiler through a sidearm, a HX, and a whole bunch of 1" copper 90's. According to my spinning flow indicator it's working great. I got them on E bay for $90 each with free shipping. 1 for the house, 1 for the shop and a spare on the shelf.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
Middle of the mitten, Michigan
« Reply #2 on: September 10, 2013, 06:02:03 PM »
just guessing but i think these pump makers will be in a very close cost range for pumps that are of comparable gpm and head range?
« Reply #3 on: September 10, 2013, 09:43:28 PM »
The NRF36 is a pretty good sized pump. Not really anything cheaper unless you go chinese.
If you just want to stay with the same pump, I may be able to get you a good deal on one. Will be way less than $300.
If you go to a Taco, the 0011 is close or the 2400-wb. Both are single speed though and yours is 3 speed.
« Reply #4 on: September 10, 2013, 09:46:10 PM »
Hey Scott
What kind of return temperature do you get when there is heat load? That pump sounds slightly small with that much on the system. If you had a plate heat exchanger instead of the sidearm it most likely wouldn't work too good since there would be larger demand when DHW is running.
« Reply #5 on: September 10, 2013, 10:53:24 PM »
Yep, could be another common case of "we'll my home is warm so i know my pump is big enough".
That's def not a good way to tell
« Reply #6 on: September 11, 2013, 05:30:58 AM »
Temperture gauges on supply and return can tell a guy a lot.
automan77
  • OWF Model: 6000
« Reply #7 on: September 11, 2013, 12:34:53 PM »
I have one on my supply line
Scott K
Stihl ms 311
Husky 455
« Reply #8 on: September 11, 2013, 12:38:14 PM »
Just grabbing the pipe can tell a lot too. If it just feels warm and the supply is hot then you probably have an undersized pump. 150° is usually about as cold as you want it to go and that temp you can probably keep your hand on the pex for at least a few seconds.
« Reply #9 on: September 12, 2013, 04:25:14 AM »
Temp gauges are relativly cheap and they can tell a lot
Chas
  • OWF Model: 6000
« Reply #10 on: September 15, 2013, 12:14:43 PM »
Ok RSI, I can now answer your question. I just did some checking and my inlet temp coming into the house was 177º,  after going thru the sidearm and the furnace HX with the furnace blower on,  my temp had dropped 30º to 147º. Is this exceptable or this an indication that my pump is to small? I'm a newbie so I don't know what the optomum temp drop across the HX is. With the furnace blower off, I have about a 2º drop from inlet to outlet, 177º to 175º.
Dolmar 035
Stihl 026
Stihl 260
John Deere 4720
Polaris Ranger 800
« Reply #11 on: September 15, 2013, 01:06:46 PM »
147 is ok but when the supply water temp drops it might go a little too low.
You might want to consider adding another pump in series and connect it to come on with the furnace blower.
« Reply #12 on: September 18, 2013, 04:31:29 AM »
temperture differential from supply to return on the wood boiler as a general rule should never be more than 20 degrees, more than 20 degrees will shock the boiler when it returns, this is thought to be one of the major problems with rot out by many of the manufacturers, do as you wish but I personally would be either upsizing the circ or putting a second circ in line to reduce resistance and get the flow up, don't put them close together or they will cavitate and destroy the circ.
« Reply #13 on: September 18, 2013, 07:09:30 AM »
Some pump manufacturers say you can bolt two pumps right together. Have you ever seen one cavitate from being to close to another?
« Reply #14 on: September 18, 2013, 08:24:24 AM »
Yes you can bolt them directly together, most companies I've talked to actually warned against separating them, said there was more risk in doing it like that vs the in series method.  We've done a lot of pumps bolted together and not had an issue.
Slim, could you explain this "shock" to me?!  Now I fully understand the science of keeping return water temps safe, but could you explain the actual science that could lead to boiler degradation if let's day your set point was 190 and it returned at 155?  Well over 20 degrees.
