Author Topic: Infared Temp Gun  (Read 8241 times)
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
Infared Temp Gun
« on: September 15, 2013, 05:49:15 PM »
Looking to buy a Infrared temp gun but don't want to spend a lot. I saw some on eBay for around 25 bucks does anyone have any recommendations on a good cheap one?
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
jerkash
  • OWF Brand: Legend
Re: Infared Temp Gun
« Reply #1 on: September 15, 2013, 06:07:17 PM »
Lowes Home Improvement had them on sale last year.  I'm thinking $29.  Seems like they were in the barbque grill section
johnybcold
  • OWF Model: Classic E1400
« Reply #2 on: September 15, 2013, 06:52:56 PM »
I got one from lowes I ordered it online and picked it up in the store it was $20-30 comes in handy I also bought a wood mosture meter
old truck
old craftsman chain saw
Polaris Sportsman 500HO
automan77
« Reply #3 on: September 18, 2013, 06:59:46 AM »
Picked one up at harbor freight.
Scott K
Stihl ms 311
Husky 455
« Reply #4 on: September 18, 2013, 08:25:55 AM »
There all over the place tho, they'll read one temp on one side of a fitting than the other, then read different on each type of material whether it be pex, brass, copper you name it.
« Reply #5 on: September 19, 2013, 07:03:44 AM »
Temperture GUAGES will tell you a lot, and they are quite accurate.
« Reply #6 on: September 19, 2013, 07:14:59 AM »
Slim is right, I've seen heat guns confuse more than it helped.
Homerglide
  • OWF Brand: Orlan EKO
  • OWF Model: Out in the shop - Model 25 gasifier
« Reply #7 on: September 19, 2013, 08:59:30 AM »
Infrared Temp Guns can be your friend
I have two infrared temperature readers (point and shoot). In the beginning they were frustrating to use, due to my ignorance. I was unaware of what they require to be accurate. These devices are finicky about the surfaces they read accurately.
1) Shiney, smooth or light colored surfaces are a no-no
There are simple fixes that will result in very close readings. Flat black paint or a strip of black friction tape will do the job. The friction tape is more accurate by a small margin.
Try either on a section of pipe. Take a shot at your new target and then a shot three inches away on bare pipe, you will see the difference. Comparing with other reading devices (strap-on bi-metal and digital thermistors) I am now comfortable with the results of the infrared devices.
Coupla Chainsaws
Axe
Strong OLD Back
2000 Dodge Cummins
« Reply #8 on: September 19, 2013, 11:39:44 AM »
Ive done that as well..  even with strap on probes on the line it reads cooler than the actual water temp, u just have to learn by how much.
if you were go place a black tape on supply line at back of stove how much differently did it read than the aquastat?
Homerglide
« Reply #9 on: October 06, 2013, 01:40:44 PM »
I have no aquastats to compare with. All sensors are thermistor including the one on top of the boiler which the boiler controller uses and is very close to actual.  The thermistors that are strapped to the pipes and wrapped with insulation are questionable (maybe 4 to 10 degrees cooler than actual).
Coupla Chainsaws
Axe
Strong OLD Back
2000 Dodge Cummins
