Author Topic: PEX Install Questions  (Read 8371 times)
uncle
« on: September 15, 2013, 08:00:40 PM »
I've got my Underground mostly installed but have a situation.
My house is on a crawl space and the utilities underground interfered with my pex underground. So I'm going to have to come above ground level for the last 6ft. I will build a patio over the pex so there won't be any trouble there but,,,,
Do I insulate the insulated pex?  Should I use foil board and box it? Foil board and wood inclosure?
I really could use some advice.
Brian
plumb bob
  • OWF Model: CL 5036
  • still green
Re: PEX Install Questions
« Reply #1 on: September 16, 2013, 06:39:04 AM »
I think most important is, will it stay dry? the more insulation the better. I would cover to protect from critters.
« Reply #2 on: September 16, 2013, 08:12:59 AM »
So your wondering if you should insulate your already insulated line because its going to be on top of the ground...
It could be a good idea I'm case of a big power failure lasting a couple days, as far as how to do it depends on where you live and how cold it gets.  We've had to do that and we'd cover it with dirt instead of digging down
uncle
« Reply #3 on: September 16, 2013, 11:44:29 AM »
I'm in Arkansas so not artic temps. I do want to protect the pipes and add a little insulation. I will have this OWB wired to my generator so I can have heat in a power outage.
The patio that I'm going to build will protect them well but I want the best setup I can have.
Brian
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #4 on: September 23, 2013, 06:57:21 AM »
Here is what I did.  I took a 4" roof flange and cut out a 6" hole, because I'm running 6" pvc.  4" may work perfectly for you.  I put frost king cellular insulation around my pex and fed it through the pvc.  Run the PVC through the flange and presto!  A little foam and silicone and it's pretty weather tight!
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
hofmus
  • OWF Brand: heatmor
  • OWF Model: 200
« Reply #5 on: September 23, 2013, 05:46:31 PM »
Was wondering if anybody has a good source for 1 1/4 PEX. I need 125 ft to complete inside install.Thanks Also, any tricks to air testing lines from house to wood boiler? I need to rig up something ..
« Last Edit: September 23, 2013, 05:48:21 PM by hofmus »
« Reply #6 on: September 23, 2013, 06:57:42 PM »
i think that was a great idea!   :thumbup:
andyhowardcity
« Reply #7 on: September 24, 2013, 06:55:14 PM »
That looks really nice and seems cost effective. I'm going to see if that will work for my application.  Thanks for posting!
Timberwolf 5000 (Installed 9/2013)
Sidearm heat exchanger (in process of being installed)
20 cords of hardwood and 10 of soft ready to go :)
Stihl MS 362
Fiskars X27
