Author Topic: glycol  (Read 8264 times)
caper
  • OWF Brand: heatmaster 5000
glycol
« on: September 23, 2013, 08:20:24 AM »
Hello everyone, im a new member, second question of the day,how much glycol should i add to my heatmaster 5000, i know it holds approx 150 gallons plus the loop into the home, im thinking approx 20 gallons maybe, just enough so that if i ever had to leave in an emergeny in the dead of winter it wouldnt freeze, would 20 gallons or so be enough, i know the pumps would be still circulating the water in the cold, but i just want to be extra safe ....thanks again..DW
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Cape Breton, Nova Scotia
Canada
Re: glycol
« Reply #1 on: September 24, 2013, 04:58:20 AM »
I don't think 20 gallons would make much of a difference, the big concern from me is a power outage while you are away, why would you not spend the money that the glycol costs on drains and snifter valves to be able to drain the boiler and blow out the lines
Re: glycol
« Reply #2 on: September 24, 2013, 05:28:17 AM »
You would need to get close to a 50/50 mix if you want complete protection.
Re: glycol
« Reply #3 on: September 24, 2013, 07:26:30 AM »
Depends on the area but around here the ratio recommended is 35%. You need to look at what you are buying though. It is common for it to come in a 70% mixture which would mean you need to mix that 50/50 to end up with 35% ratio.
Re: glycol
« Reply #4 on: September 24, 2013, 07:31:26 AM »
I don't see how it's worth it, I've never heard of many issues with a boiler freezing, now I assume if you planned to be gone 3 weeks in the winter and lived in Minnesota and there was a power outage it could happen but def not under any kind of normal circumstances.
Where do you live!?
Re: glycol
« Reply #5 on: September 24, 2013, 07:47:04 AM »
Even then, unless you do it a lot or have to leave suddenly, I would just set it up to drain before you leave. The put a couple gallons on rv antifreeze in the lines and boiler to make sure no trapped water will freeze.
caper
Re: glycol
« Reply #6 on: September 24, 2013, 05:59:28 PM »
THANKS EVERYONE FOR THE ADVICE, I THINK I STILL WANT ALITTLE GLYCOL IN THE SYSTEM THO, IM JUST THINKING IF WE EVER HEAD DOWN SOUTH OR ANYTHING IN THE FUTURE, WE LIVE IN NOVA SCOTIA AND OUR WINTERS ARE NOT THAT BAD,OTHER THEN A FEW  COLD WEEKS IN FEB AND I REALLY DONT FEEL LIKE DRAINING THE SYSTEM,HOWEVER IF I HAD TOO I WOULD,ONCE AGAIN THANKS FOR THE ADVICE, VERY INTERESTING SITE I MAY ADD, IM GETTING ADDICTED TO IT ALREADY.....
husky 555
Toyota 4x4
grizzly 700
Harley Street Glide
Canada
Re: glycol
« Reply #7 on: September 24, 2013, 06:35:59 PM »
Before you do it, I would find a temperature chart from the glycol manufacturer. 20 gallons might only get you a couple degrees before freezing.
50 gallons of 100% glycol is probably the minimum to actually be safe.
Re: glycol
« Reply #8 on: September 24, 2013, 06:45:05 PM »
Then when we have our first rookie boil over, which we all do
all that glycol will be gone
