Author Topic: Wraparound pump size  (Read 5101 times)
MaverickM23
  • OWF Brand: Empyre
  • OWF Model: Pro 200
« on: September 25, 2013, 09:08:21 AM »
Putting in my new outdoor wood boiler and I am connecting it to a pressurized hot water oil fired boiler. I am using a water to water exchanger so they will be on their own loops so to speak. My question is do I need a circulator to run through the oil boiler to keep it hot at all times? Central boiler has a diagram and they call it a wraparound pump. How would I size it or know which one to get?
Re: Wraparound pump size
« Reply #1 on: September 25, 2013, 11:36:18 AM »
If you want the indoor boiler to stay hot all the time you will need to add the pump. If you happen to have a pump on the indoor boiler that runs 24/7 (or could be changed to run 24/7 without screwing up the system) then just put the heat exchanger in series with it.
If the indoor boiler does not need to stay hot, you can probably use a strap on aquastat to disable it when the OWB pipes are hot.
The pump would depend on heat exchanger size. Most likely something like a Grundfos 15-58 will work since there isn't much to pump through. If you can keep the pipes large and have a large heat exchanger a Taco 007 will move more water.
