Author Topic: Check Valve in Pump Yes or No  (Read 7562 times)
uncle
« on: October 04, 2013, 01:39:32 PM »
My pumps have a check valve in the inlet. Do I keep them in or pull them out?
Do these effect the flow charactoristics of the pump?
Brian
uncle
Re: Check Valve in Pump Yes or No
« Reply #1 on: October 04, 2013, 07:07:51 PM »
pump runs single loop from OWB to house heat exchanger.
uncle
« Reply #2 on: October 06, 2013, 08:06:00 PM »
Thanks for the info.
Brian
« Reply #3 on: October 06, 2013, 09:17:47 PM »
It does restrict flow a little. See flow for a Grundfos 15-58 below.
Also, it can cause the pump to get airlocked in certain situations so best to just remove it if it isn't needed.
« Reply #4 on: October 07, 2013, 12:09:34 PM »
Absolutely get rid of it on the wood boiler loop, get all the plastic out, if you bring your water feed in between 2 ball valves it allows you to fill the boiler from the supply or the return, thus pushing any air that is trapped back to the wood boiler and vented out the top
uncle
« Reply #5 on: October 07, 2013, 08:08:07 PM »
I didn't think about that, Thanks
Brian
