Author Topic: Overnight shut down  (Read 7392 times)
Fyfer
  • OWF Model: E 2400
Overnight shut down
« on: November 06, 2013, 07:51:35 AM »
Good morning everyone.
Just got and hooked up a CB e2400 this fall and have burned it for a few days now.
All seemed to be going well until this am when I walked out to check the fire and noticed the the power to the unit was off.
I checked the power button on the unit and the breaker in the garage. Both are on.
I have only had 3-4 days of burning and performed no maintenance yet.
Any thoughts on how to get powered back up?
jcc273
  • OWF Model: H2
Re: Overnight shut down
« Reply #1 on: November 06, 2013, 10:35:49 AM »
I would get a meter and started reading voltages at different places to figure out where the issue is.  maybe a short somewhere.
One time i actually hooked up an old pump and it shorted out and instead of flipping the breaker it actually burned up the wire somewhere between the breaker box and the pump like a fuse.  had to run new wire from box to unit hahaha.
Anyways try and figure out where the voltage dissappears to try and narrow down the problem area.
Jarrod
Hardy - H2
Northwestern PA
the trailmaster
  • OWF Brand: CENTRAL BOILER
  • OWF Model: 2400
« Reply #2 on: November 06, 2013, 02:55:42 PM »
You have a fuse at the unit that may be blown.  If you replace and it and it blows again, call your dealer.  He will ask you to do some test at the Firestar Control panel which should indicate if your panel needs to be replaced.  Good luck
Trailmaster  Plymouth NH
« Reply #3 on: November 06, 2013, 03:27:25 PM »
Honestly guys, not trying to slam anybody, in your opinion, is that fancy controller worth it or do you in your opinion think it's all necessary, just want your opinion, as some have said in the industry that it helps, I however doubt the real need. I would like to see some real tests, identical units, same fuel. anybody have any thoughts.
nightowl
  • OWF Brand: central boiler
  • OWF Model: e1400
« Reply #4 on: November 06, 2013, 07:29:00 PM »
same thing happened to my e1400.traced it backed to a led light in sofit that shorted and put load on the 24volt xfrm and fryied it causing the firestar to not work it all works off 24 volts.cb said they now put an inline fuse just for led lights.
« Reply #5 on: November 07, 2013, 08:51:17 AM »
They sure have enough issues out of these fancy control boards, I'm not trying to knock them but here and on the cb section it's electrical issue upon another
Roger2561
« Reply #6 on: November 07, 2013, 09:57:10 AM »
I'm going into 3rd year heating my home and DHW with my CB E-Classic 1400 and I have not experienced the problems with mine that others have had with theirs.  The one problem I had was through my own dang fault.  Perhaps mine was built on day other than a Friday or Monday...  ;)  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
Fyfer
  • OWF Model: E 2400
« Reply #7 on: November 11, 2013, 07:40:25 PM »
Got it all sorted.
Thanks for your input.
Seems the breaker in the house had a faulty connection.
Working again.
