Author Topic: Installing bleeder valve.  (Read 6698 times)
4CSTRAILS
  • OWF Brand: Dahl
  • OWF Model: 230
« on: November 06, 2013, 12:48:53 PM »
This is my first attempt at installing supply and return lines. My pump is in the basement about half way between OWF and heat exchanger.Where should I put a valve in case I need to bleed air from the system? Total distance is about 50 feet. Also, after I suspended my heat exchanger above the oil furnace on the "after blower" side I have a stronger than normal fuel oil smell when the furnace kicks in. I know this will not be there after I shut down the oil furnace and fire up the OWF but am I restricting normal flow in some way?
Re: Installing bleeder valve.
« Reply #1 on: November 06, 2013, 02:15:48 PM »
If you are getting an oil smell, the heat exchanger in your oil furnace is cracked or the oil burner needs cleaning, get a pro to service the oil burner before you kill your family, seriously.
« Reply #2 on: November 17, 2013, 12:58:47 PM »
air bleeders go high in the system, ideally the highest point and any dead head that won't get flow.
« Reply #3 on: November 17, 2013, 03:27:32 PM »
If the furnace is higher than the pump then you shouldn't need a air bleeder on a 50ft run. If the pump is the high spot on the system you need to seriously need to consider moving it out onto the furnace.
« Reply #4 on: November 17, 2013, 04:05:02 PM »
What ever happened with the oil smell
