Author Topic: Low water cut off switch  (Read 4863 times)
« on: November 17, 2013, 07:05:44 PM »
Looking to add a simple low water cut off switch to my hardy. I would put it up in the little tank on the back that I use to check the level. I would want it to simply allow the hot wire to run through it and break the connection if the water dropped below a certain point for some reason. Any ideas?
Re: Low water cut off switch
« Reply #1 on: November 18, 2013, 05:05:33 AM »
Safegaurd low water cutoff, works well on pressurized system.
« Reply #2 on: November 18, 2013, 07:46:24 AM »
Thanks slim, looks to be the least expensive option out there. Should work for the application.
« Reply #3 on: November 18, 2013, 05:52:38 PM »
Picked one up off eBay today for 62 shipped. Thanks again.
« Reply #4 on: January 16, 2014, 07:32:06 PM »
I took a slightly different route, I used a low pressure diaphragm switch (like for a well or air compressor). Placed it in a tee in the first connection in the basement, if you lose pressure the switch opens which opens a constant duty relay and it kills power to everything until the water level is replenished. Have a momentary on pushbutton switch to act as a bypass or primer until the pump builds pressure.
Only needed it once so far when an older style of compression fitting failed the year after I got my boiler hooked up and running.
