Author Topic: Hot Tub Motor  (Read 6920 times)
CountryBoyJohn
  • OWF Model: MF 10,000 E
Hot Tub Motor
« on: November 18, 2013, 05:18:36 AM »
Does anyone have any experience with the pumps/motors that run the hot tub?  I got all my stove connections made, wired up, and functioning.  But, when I started filling the tub and testing the motors, I have one motor where the shaft turns freely, but the motor won't turn it.  I hear it hum when I turn it on, and then I hear what sounds like a switch in the motor turn off then the humming stops after 4 or 5 seconds.  Then, about a minute later, it does the same thing.  Almost like it is trying to turn the motor again.  Any thoughts?
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
Johnv656
Re: Hot Tub Motor
« Reply #1 on: November 18, 2013, 12:27:26 PM »
Ours did that, ended up replacing the motor
ITO
  • OWF Brand: HS1
  • OWF Model: 555
Re: Hot Tub Motor
« Reply #2 on: November 18, 2013, 01:27:54 PM »
 Sounds like the motor's internal (Klixon) thermal overload element is sensing high current (heat) and then opening but once it cools it closes then it starts all over again. Does the motor have an external capacitor mounted on it (a cap start motor has a bulged metal cover on the outside containing the capacitor)? If so it may only need a capacitor which is pretty cheap. This link is pretty helpful and no I'm not a salesman!
http://www.spadepot.com/spacyclopedia/pumps.htm
CountryBoyJohn
Re: Hot Tub Motor
« Reply #3 on: November 19, 2013, 05:37:34 AM »
Thanks ITO.  I got the motor out and am taking it to a place today.  I'm hoping it's just the capacitor.  I don't have the hump, but I think it is on the end of the motor.  That link was a good read.
Stihl MS290
Woodchuck Log Jack
Knox County, IN
CountryBoyJohn
Re: Hot Tub Motor
« Reply #4 on: November 19, 2013, 11:33:31 AM »
Bad capacitor.  $7.50 for a new capacitor.  $17.50 for the guy to test it and confirm that it is indeed the capacitor.
Stihl MS290
Woodchuck Log Jack
Knox County, IN
ITO
  • OWF Brand: HS1
  • OWF Model: 555
Re: Hot Tub Motor
« Reply #5 on: November 19, 2013, 11:51:45 AM »
 Kind of unusual to see a cap start motor with an internal capacitor but they are obviously out there!
 I dont know how old your pump is but you may consider putting a new wet end on the pump while you have it out, that makes a whale of a difference if the impeller is worn at all. Usually the wet end is pretty easy to change and cost about $40.
gsilus
  • OWF Model: E2300
Re: Hot Tub Motor
« Reply #6 on: December 31, 2013, 04:10:10 PM »
CountryBoyJohn, Sounds like you got by with not much expense :)
Nice to have such a forum to get ideas from and help.
Re: Hot Tub Motor
« Reply #7 on: February 28, 2014, 09:17:39 PM »
Bad capacitor was the first thing that came to mind when you described your symptoms.
Capacitor start motors also have a centrifugal switch in them that can go bad.
Glad we went to three phase on as much stuff as possible, single phase motors are a pain in the but.
