Pages: [1] 2 3
Author Topic: Grundfos 15-58 Check Valve?  (Read 33334 times)
WoodMOJoe
« on: November 21, 2013, 12:14:01 PM »
There is a little white plastic piece in the outlet end of my pump.  Is that the check valve and do I want it in there?
uncle
Re: Grundfos 15-58 Check Valve?
« Reply #1 on: November 21, 2013, 01:44:45 PM »
I was advised to pull mine out and I've had no negatives to this.
Brian
WoodMOJoe
« Reply #2 on: November 21, 2013, 05:31:38 PM »
Brian
Thanks Brian, yeh it looks like it would really restrict the flow, can't imagine what it's purpose would be in my system.
« Reply #3 on: November 21, 2013, 09:56:28 PM »
If it is your main boiler pump, pull it out. If you are using one something else like in-floor heat, leave it in.
WoodMOJoe
« Reply #4 on: November 22, 2013, 06:32:26 AM »
Yes, it is my main boiler pump, will leave it in, thanks.
« Reply #5 on: November 22, 2013, 07:44:29 AM »
I'm using mine to circulate water between the oil burner and the flat plate heat exchanger.  I left it in but should I remove it?  Thanks, Roger
WoodMOJoe
« Reply #6 on: November 22, 2013, 01:09:48 PM »
Was a long day yesterday, I meant I will TAKE IT OUT!   :bash:   ;D
WoodMOJoe
« Reply #7 on: November 25, 2013, 03:38:18 PM »
When I went to pull the check valve out I just got half of it I think?
Do I need to get the white piece out in the pic below?  If so anybody know any tricks to do that?
« Reply #8 on: November 25, 2013, 03:40:05 PM »
It should all come out.
Can you hook it with something like an allen wrench?
WoodMOJoe
« Reply #9 on: November 25, 2013, 03:56:41 PM »
It's in there real tight but I will figure out something to pull it out, just wanted to make sure it was supposed to.  Thanks RSI.
« Reply #10 on: November 25, 2013, 06:30:21 PM »
mine did not come out easlily either...i grabbed it with pliers but it came out in a couple of pieces
« Reply #11 on: November 25, 2013, 07:10:08 PM »
The best tool I've found for that job is the saw blade on my leatherman (wave), it works great, don't cut yourself, it hurts!
WoodMOJoe
« Reply #12 on: November 25, 2013, 08:09:13 PM »
Yeh, I think I will have to break it in pieces to get it out, will try again tomorrow.
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
« Reply #13 on: November 26, 2013, 05:21:07 AM »
 I tried to remove mine also and the large diameter white that fits in the cast bore would not come out. Used a to pry the edge back and could see what looks like an O-ring behind it and then it flares out wider still as if it is installed from the inside if the pump.
WARNING - DO NOT use a heat gun in attempt to make it softer to remove. The impeller will not take it!!!
On a related note does anyone know if a rebuild kit is available for a 26-99? This bonehead was determined to get that white part out.
WoodMOJoe
« Reply #14 on: November 26, 2013, 05:44:14 AM »
I did some Googling and found this (from 2006):
"Grundfos internal check valves are friction fitted in the outlet of the pump and have been successfully applied in the field for over 5 years. The location in the outlet of the pump allows for easy removal, if desired, but the low pressure drop design of the product makes it optional - pump performance with and without the valves are nearly identical."
Don't know if that is true or not but I am now thinking I may just leave the white part that is still in the pump.
Pages: [1] 2 3
