Author Topic: manifold setup  (Read 5197 times)
birchbark
  • OWF Model: 10000e
manifold setup
« on: November 21, 2013, 07:23:09 PM »
I just recently installed 1"1/4 thermopex and a new Mr Pex manifold.  With the manifold I have 5 circuits feeding baseboard rads, heat HX in the furnace duct and the hot water tank.  My question is should I setup the manifold circuits so that all runs have the same flow rate, or should I set up the runs to all have the same return temp.
hoardac
  • OWF Brand: Heatmaster G-200
Re: manifold setup
« Reply #1 on: November 24, 2013, 07:55:31 AM »
All of my circuits have their own flow rate to adjust for what heat each one needs, some need to be wide open some do not. They share a common return to the plate exchanger.
