Author Topic: Looking to have a remote temp indication in house  (Read 13618 times)
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« on: November 26, 2013, 07:06:37 AM »
Does anyone have a suggestion for installing a wireless boiler temp indication in the house to monitor the water temp ::)
New Holland TC30 tractor
powerdiver6000@aol.com
andyhowardcity
Re: Looking to have a remote temp indication in house
« Reply #1 on: November 26, 2013, 05:56:51 PM »
What about a WIFI camera pointed to the gauge/stove so you could monitor the whole operation.  Looks like they start around $50 or so.
Timberwolf 5000 (Installed 9/2013)
Sidearm heat exchanger (in process of being installed)
20 cords of hardwood and 10 of soft ready to go :)
Stihl MS 362
Fiskars X27
Jack72
  • OWF Model: E-1450 (11)
« Reply #2 on: November 27, 2013, 05:48:30 AM »
Pwdiver
The wireless camera didn't work for me because it's on my backside of my garage (snowy picture). their is probably better ones and more money that would fix that.             but I have a wired camera. It works great(crystal clear picture) I don't have the WIFI one right now   it only goes directly to my TV I can click on it at any time to see what is doing.  It came with 100 ft of cable which I only knifed in about 6inches in the ground.  I can give my exact model if this sounds good for you this will be fourth year no problems at all.  Less than 100 bucks for everything.
Chevy 2500 HD 13 Duramax
Stihl 046 036 009
Northern Tool 25 ton Splitter
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« Reply #3 on: November 27, 2013, 06:13:41 AM »
Thanks for the info, I have a linksys wireless camera but cant find the driver disk for it. What model of wired camera do you have :D
Chas
« Reply #4 on: November 27, 2013, 06:18:32 AM »
When I buried my Thermopex I also buried 2-  3/4" pvc conduits. I ran a type j thermocouple wiire from a temperature probe in the oulet of the boiler and hooked it an Amtec DT-8350 digital thermometer 180' away in the house. I calibrated it to read the same temp as the boiler read out. It works great!
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
Jack72
« Reply #5 on: November 27, 2013, 09:21:14 AM »
Pwdiver
Hmmm yes that is a problem  I wonder if you could download off the internet somehow??
 We are out of the state right now for Thanksgiving I will send you a video of it on my TV so you can see the clarity of it when I get home and the model for you.
Stihl 046 036 009
JDfarmer
  • OWF Brand: NCB 250 coal
  • OWF Model: NCB 250 Coal
« Reply #6 on: November 27, 2013, 01:36:53 PM »
Forget the camera. Too complicated and poor resolution for far away. Also, need a monitor or a tv.
Most people use a wireless meat thermometer;
Oregon Scientific AW131 Grill Right Wireless Talking BBQ/Oven Thermometer
Main unit will receive the probe signal from up to 330 feet away.
Sensor has temperature range from 32°F to 572°F
It's like it was made for a boiler :) ;D
Good luck.
Wrudoing
  • OWF Brand: Central boiler
« Reply #7 on: November 27, 2013, 06:39:31 PM »
   PN 5052 page 17 in the central boiler parts catalog indoor temp indicator
I have two of them there off by about 10 degrees but gives you a good idea what things are doing
It's not wireless but you just tee into the line in the basement and run your wire real easy install
« Last Edit: November 27, 2013, 06:42:52 PM by Wrudoing »
homelite
  • OWF Model: 4030
« Reply #8 on: December 03, 2013, 08:19:57 AM »
Got mine off Ebay works great.
muffin
« Reply #9 on: December 03, 2013, 09:05:58 AM »
I use a dual probe meat thermometer, wireless.  Got it off ebay for like $50.  It monitors the supply and return right as it comes in the house.  Has alarms for over and under temp.  works great.
chillyhiker
« Reply #10 on: December 10, 2013, 01:01:03 PM »
Just curious how you mont the probe to the owb...?
stihl chain saws
husky spliter
 trailer for haulin wood.
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« Reply #11 on: January 10, 2014, 05:10:03 AM »
I ordered the Oregon Scientific AW131 Grill Right Wireless Talking BBQ/Oven Thermometer off of ebay this worked for a day then the the probe went bad I had put it in the top of the boiler where you add water to it, it appeared to be stainless steel braided wire going to the probe.  It must have shorted the probe because it went from 155 to 216 degree's the boiler never got that hot. :bash:
AirForcePOL
  • OWF Model: G400
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
pwdiver
  • OWF Model: CL5036
    • narronseggstra's
« Reply #13 on: January 10, 2014, 03:34:01 PM »
I can sell this one real cheap I e-mailed Oregon  scientific about a replacement probe never heard anything back from them :'(
JDfarmer
« Reply #14 on: January 11, 2014, 11:15:01 AM »
Here is my set up. It's accurate to 1F.
I mount the BBQ probe flat against the water tank heat exchanger in the house, not on the boiler.
(if you mount it outside; and if the unit looses connection, you would have to go outside to the boiler and re-establish connection every time).
Than I cover it with 1" coper pipe foam insulation. Wrap to secure with tape.
VERY IMPORTANT!!!
I don't know why, but the BBQ unit most often will not work properly if you use the battery that the unit comes with.
I had an issues that it kept loosing connection. When I researched it, I saw that if you change the battery, it works fine.
I did that and no issue at all.
I got this unit on Amazon for $39.95.
Oh, I also cut the wire in the unit to the speaker to stop the annoying beeping.
Works awesome.
As you can see it, no need to mount the probe on the boiler. It's accurate to 1F if you mount it like I did n the water tank exchanger.
For some reason my pictures won't post:(
ET-732 BBQ monitor
http://www.amazon.com/Maverick-Et-732-Remote-Smoker-Thermometer/dp/B004IMA718/ref=sr_1_1?ie=UTF8&qid=1389463627&sr=8-1&keywords=et+732+maverick
