Author Topic: fitting leaking lok at this  (Read 9242 times)
CRJR
Re: fitting leaking lok at this
« Reply #15 on: May 13, 2014, 02:59:12 PM »
One of the guys I work with has had to replace 2 elbows in his system in the last 3-4 months because of the exact same type of pitting in his fittings. The dezincification was just a thought.
CRJR
« Reply #16 on: May 13, 2014, 03:01:02 PM »
I hope someone on here can help
gainerspot
  • OWF Brand: P&M
  • OWF Model: Ultimizer BL 2840 (soon)
« Reply #17 on: May 19, 2014, 08:05:35 PM »
When I do my install I was going to avoid using 90 and use PEX Bend Supports.  You just put your pex pipe in it and it curves the 90.
 http://www.amazon.com/SharkBite-23051-Supports-Polymer-4-Inch/dp/B007AGKHIW/ref=sr_1_3?ie=UTF8&qid=1400551226&sr=8-3&keywords=PEX+Bend+Supports
I would also read up selecting the correct circulators and make sure that you have the right pump for your application.  Here is a great link.
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« Reply #18 on: May 19, 2014, 08:42:19 PM »
That is good practice, we only use 90's when absolute necessary
Michigan Thumber
