Pages: [1] 2 3
Author Topic: whats kind of underground piping should i use??????  (Read 20679 times)
andyjs
  • OWF Brand: heatmaster
  • OWF Model: 10000e
« on: December 04, 2013, 11:18:23 AM »
Need to replace my underground pipe to boiler just wanted some opinions.I have a 4 foot wide path 150 feet to the house snow melted my pipes are junk!
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: whats kind of underground piping should i use??????
« Reply #1 on: December 04, 2013, 11:34:08 AM »
Depends on your financial situation.  Do you want to pay $5, $10, or $15 per foot?  Also note, that underground piping is YGWYPF.  You Get What You Pay For.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
andyjs
  • OWF Model: 10000e
« Reply #2 on: December 04, 2013, 11:42:41 AM »
I learned that the last time paid 6 bucks a foot and its junk.just wanted opinions on like a 5 wrap or thermopex?
racnruss
« Reply #3 on: December 04, 2013, 12:02:28 PM »
my snow melts between my boiler and garage too.  Luckily it is only about a 20 foot run.
I think the next time I put pipe underground I am going to put my insulated pex-in-black pipe INSIDE a 6 inch hard PVC pipe with the joints glued and elbowed up to above ground on both ends.  That way the cold, damp earth can't even touch the black tile pipe.
CountryBoyJohn
« Reply #4 on: December 04, 2013, 12:08:01 PM »
Your Cadillac best of the best option is Logstor.  There are a lot of guys on here who have lost faith in Thermo-pex.  The cheaper option the guys on here endorse is the 5-wrap.  I think most are in agreement with what racnruss mentioned: sleeving the insulated pipe in a solid smooth plastic pipe.  Schedule 30, 40 or something like that.
Stihl MS290
Woodchuck Log Jack
Knox County, IN
andyjs
  • OWF Model: 10000e
« Reply #5 on: December 04, 2013, 02:42:24 PM »
http://m.ebay.com/itm/250748766468?cmd=VIDESC&gxo=true I found this 5 wrap on eBay is it any good?
« Reply #6 on: December 04, 2013, 03:07:38 PM »
I dug a trench with a mini excavator, put down thick plastic sheeting the entire length of the trench, put my pipes in the trench, and spray foamed it.  I lifted up and separated the pipes about an inch as I went along and sprayed as I went.  In the 80 feet between boiler and house, I have a 0 degree heat loss and my snow have never melted over the piping.  The pipes enter the house only about 1' under ground too.  Closed cell spray foam wrapped in plastic keeps the water out and the heat in.
andyjs
  • OWF Model: 10000e
« Reply #7 on: December 04, 2013, 03:24:03 PM »
Where did u buy the spray foam?
« Reply #8 on: December 04, 2013, 03:52:37 PM »
+1 on the in ground spray foam. I have a 100 foot run and lose 1 degree. I had a guy come and spray it. He sprayed my water jacket on my boiler + 100 feet of line for $500.
cantoo
  • OWF Brand: Western Pacific
« Reply #9 on: December 04, 2013, 06:22:15 PM »
That pipe looks good but do you know what type of tile it's actually in?
 This picture is of a 3 year old SOLID drainage tile buried 4' deep, poplar trees are minimum of 25' away. Enlarge the pictures to really see the roots. I had to cut the tile in half just to remove the roots. I have since replaced this tile with 4" PVC solid sewer pipe.
 PS, I used logstor on my own install, I also did another short run of 30' of 4" PVC with foam insulation on the lines just to see if there was a difference.
« Reply #10 on: December 04, 2013, 06:41:43 PM »
All I got to say is spend the $$$ for the good pipe..Id be buying it from the dealer of your boiler …Maybe look into central boiler piping as an option too.. Def don't do the home depot way…If your buying online..Just be careful what you buy
ITO
  • OWF Brand: HS1
  • OWF Model: 555
« Reply #11 on: December 04, 2013, 06:52:34 PM »
 I used this for a run and no complaints:
http://www.pr.com/press-release/342081
cantoo
« Reply #12 on: December 04, 2013, 07:27:09 PM »
Maybe some of these companies should test their pipe in a swimming pool or water tank to check the heat loss? Would this not be a fairer test than laying it on the ground or floor and seeing what the temperature loss is? Are there any dealers on here who sell the foam wrapped in a corrugated type tile that would test theirs? It would be an easy test to do in a tank using a coil of pipe.
« Reply #13 on: December 04, 2013, 07:31:30 PM »
if you goto the website of a manufacturer you amy see how they tested their pipes...i think i seen one that said it was in 32 degree earth and at 5 gpm of 180 degree water
i have seen others that pump the water faster  (as high as 10gpm) to make the numbers look better
cantoo
« Reply #14 on: December 04, 2013, 07:51:25 PM »
But do they submerge it in water? I spent hours reading online before I bought my line and it seems to me that almost every problem was water infiltration of the line. So it would make sense to me to test the pipe under water to see how it does. Even an air test of the actual tile would tell you if it leaks or not. I bought a roll of solid field tile and it was full of holes ( from rubbing during shipping, manufacturing flaws etc) so I took it back.
Pages: [1] 2 3
