Author Topic: strap on  (Read 7462 times)
woodywoodchucker
  • OWF Brand: cental boiler
  • OWF Model: classic 5036
strap on
« on: December 11, 2013, 03:15:23 PM »
Ez now. I had a guy over and had him check out my system. He said that he would put on a strap on themostat on the discharge pipe on the boiler that would shut off  power to the damper if the temp drops below 160 degs. anyone done this?
I work long shifts and on cold nights the damper is open and theres no fire or wood. The damper would be closed and stop cold air from going through the boiler.
 sounds like a great idea to me.
Re: strap on
« Reply #1 on: December 11, 2013, 03:52:29 PM »
I have a 200* snap disc wired inline with my blower and solenoid incase my aquastat sticks. Kind of the same idea except in the opposite direction.  I use to worry about boiling the water off if something went wrong and destroying the boiler. I feel much more comfortable now.
« Last Edit: December 12, 2013, 12:39:07 PM by hondaracer2oo4 »
woodywoodchucker
Re: strap on
« Reply #2 on: December 11, 2013, 05:30:58 PM »
has it payed off? ive never had that issue.
Re: strap on
« Reply #3 on: December 11, 2013, 06:56:05 PM »
WOW I preach this all the time, trust him.
Re: strap on
« Reply #4 on: December 11, 2013, 07:02:15 PM »
first OWB i ever saw had a high  and low temp snap discs high side was cut power at 190 and reset at 150 and cut power  on the low end at 140 and was a manual reset
Re: strap on
« Reply #5 on: December 11, 2013, 07:06:57 PM »
A 60 minute 110 volt timer wired in parralel to the strap on aquastat works very well, short money very effective
MattyNH
  • OWF Model: 7300E ; S-275
Re: strap on
« Reply #6 on: December 11, 2013, 07:09:18 PM »
Good idea for sure!..But I would want it shut off at a lower temp for me.. I would want it shut off 140F..Obviously the fire is out lol.
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
Re: strap on
« Reply #7 on: December 11, 2013, 07:12:27 PM »
Each boiler is different, I always run gassers hot, you are out of fuel or something is wrong at below 160 with our unit, lets figure out why?
ITO
  • OWF Brand: HS1
  • OWF Model: 555
Re: strap on
« Reply #8 on: December 11, 2013, 08:03:03 PM »
 I wired mine this way about 7 years ago, has saved my coals many a time, if I get done work late and come back on a cold evening I would always have to start a fire so I used a well type (no strap ons for me) set at 140 to shut down the draft fan so it wouldn't blow the coals out. Works well for me, you need a bypass switch once you get home and throw in some wood, don't forget to reset the switch when temps come up!
fryedaddy
  • OWF Model: 750 Gallon
Re: strap on
« Reply #9 on: December 12, 2013, 08:25:46 AM »
I have a timer on mine that shuts the fan down after 8-12hrs depending on my load.
My situation is different though, I have 700+ gallons in my stove.
MattyNH
Re: strap on
« Reply #10 on: December 12, 2013, 06:36:22 PM »
Man thats a lot of water 8)...
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
woodywoodchucker
Re: strap on
« Reply #11 on: December 19, 2013, 03:19:01 AM »
The 165/170 deg shut off is what Im after with mine. Im running my 5036 at 185/195.At 170 its out of fuel. I also want to wire a switch that interupts the power to my wall hung gas job until the temp drops to 165. Just resently I was going away over night and the low tept was forcasted to be -10. I stoked woody and put him in stand by and put on the Baxi til i got home. Worked great. I wished Id thought of that trick years ago.
