Author Topic: Cycle rate??  (Read 6966 times)
newmanab
  • OWF Brand: Central boiler
  • OWF Model: CB6048
Cycle rate??
« on: December 17, 2013, 10:14:11 AM »
Just curious how often does your wood burner cycle??  I have a CB6048 that cycles about every 2-2.5 hour... I understand it depends on heat load. This is the rate@ 20f outside
What i'm heating: 3000 sqft house
1000sqft pole barn spray foamed
What's your rate??
FYI: i moniter with an X300
AirForcePOL
  • OWF Model: G400
Re: Cycle rate??
« Reply #1 on: December 17, 2013, 03:05:02 PM »
I have never really paid too much attention to mine, but I would guess that it cycles about every hour or maybe even less than that.  Only heating 1500 sq ft.  There is some insulation missing off one side of my stove though.  Oh well, it's just wood right?
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
Jeff5036
  • OWF Model: 5036
Re: Cycle rate??
« Reply #2 on: December 17, 2013, 03:38:12 PM »
Mine depends a lot on demand and temps outside.  Heating 2200 square foot house and a 600 sq ft man cave with a basement.  Usually cycles at least once every hour to hour and a half.
Re: Cycle rate??
« Reply #3 on: December 17, 2013, 03:43:02 PM »
cycle times would have to do with everything from insulation of the home...difference in outside and inside temps, spread between aquastat temps and even capacity of the stove itself....you not happy with cycle times...well you have spent the money on a stove, now the money you save by not having to buy fuel you can spend on insualting the house or new windows ect. (things to make the home more comfortable....not beer!)
newmanab
  • OWF Model: CB6048
Re: Cycle rate??
« Reply #4 on: December 17, 2013, 08:18:37 PM »
Beer could be more fun! :P
My house is insulated fairly decent..  I may be trying to out think myself.
I was just checking what others results were.
LittleJohn
  • OWF Model: E-Classic 2400
  • Lonsdale, MN
Re: Cycle rate??
« Reply #5 on: December 18, 2013, 06:50:38 AM »
I am on board with AirForcoPOL; never really looked at how often the boiler goes, I am more concerned with how often I have to feed the beast.  Typically twice a day, except for last week had some trouble with the in-slab not working, luckily the second floor heat worked so it kept the buliding warm enought to work in (still finishing interior, hanging doors, painting, installing cabinets and flooring).  Once figured out issue (check valve in backward), that boiler was a rolling almost a constant plume of smoke, kept putting fire out
woodywoodchucker
  • OWF Brand: cental boiler
  • OWF Model: classic 5036
Re: Cycle rate??
« Reply #6 on: December 19, 2013, 03:30:05 AM »
Im not sure about burn cycles. I do fill mine twic a day at 20*f .Im heating a 28x44 cape with cathredral ceilings and 9 foot walls.Also im missing doors and window trim. Maybe less beer and more doors and trim is in order. Less snowmobiling and motorcycle riding too for that matter.
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
Re: Cycle rate??
« Reply #7 on: December 19, 2013, 06:00:17 AM »
  Woody, did you run out of wood and burn the doors and trim??
