Author Topic: going the distance??  (Read 18678 times)
pointer80
  • OWF Brand: woodmaster
  • OWF Model: 4400 heavy duty
« on: December 20, 2013, 11:55:41 AM »
Hi all,  I was just curious,  What is the distance between your OWB.  and your building or dwelling you are heating?  I have a Woodmaster 4400 heavy duty and it is about 90-100 feet from my house and about 20 feet from my barn.  Thanks all.
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: going the distance??
« Reply #1 on: December 20, 2013, 12:58:29 PM »
I'm about 6' away from my garage.  :thumbup:
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
Roger2561
« Reply #2 on: December 20, 2013, 01:05:50 PM »
My OWB is about 30 feet from the house but the piping runs about 80' underground due to where it enters the foundations into the basement.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
Brad
  • OWF Model: H5
« Reply #3 on: December 20, 2013, 01:52:15 PM »
My OWB is about 25-30 feet from my house.  Glad it's not any further cause digging 30ft of trench was killer...
Aitkin, Minnesota
ITO
  • OWF Brand: HS1
  • OWF Model: 555
« Reply #4 on: December 20, 2013, 02:19:03 PM »
Pointer I have just about the same as you, about 90' because I remember pulling in 2 pieces of 1" pex that were 100 foot pieces I cut a little off and there's a little down in back of the boiler and a bit up into my utility room.
plumb bob
  • OWF Model: CL 5036
  • still green
« Reply #5 on: December 20, 2013, 03:13:38 PM »
10' to garage, underground, then 30' along back wall of heated garage into mechanical room. the 40' into mech room is central boiler wrapped insulated pipe.
automan77
  • OWF Brand: ridgewood
  • OWF Model: 6000
  • Just say no to propane
« Reply #6 on: December 20, 2013, 03:49:47 PM »
mine is 106 from boiler to the house then 45 across the basement to my furnace.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
merrellroofing
  • Guest
« Reply #7 on: December 20, 2013, 03:56:11 PM »
165 ft. of thermopex. $ouch$.  It was the best spot for it to go.
willowbk
  • OWF Brand: port/main
  • OWF Model: 250
« Reply #8 on: December 20, 2013, 03:58:25 PM »
well looks like i got the record so far, i had to go 225 ft from the house due to the communist state of ct's regs.
otherwise i wouldnt have been able to install one, it defnitely drove up my costs quite abit. i went with the good insulated pipe and dug the trench myself w/ machine to save money. i was told you only loose less than 1/2 degree every 100 ft.
« Reply #9 on: December 20, 2013, 04:16:20 PM »
250 feet
fireboss
  • OWF Brand: central boiler
  • OWF Model: 6048
« Reply #10 on: December 20, 2013, 05:04:37 PM »
I am 14' away from my house
BoilerHouse
  • OWF Brand: Home Built
« Reply #11 on: December 20, 2013, 05:05:44 PM »
165 feet from the house, 90 feet from the garage.
Muskoka, Ont
baldwin racing
« Reply #12 on: December 20, 2013, 05:09:05 PM »
my boiler is 125 feet from house and as of right now 16 feet from shop in the little insulated building until I add on my shop..... :thumbup:
kelly
husqvarna 357 xp
farmall H
beeman
  • OWF Brand: homemade
« Reply #13 on: December 20, 2013, 06:30:22 PM »
about ten feet for me it was suposed to be one year just to test for the first winter on winter 3 now getting to like not walking far manly in the morning have bad habet of not wearing shoes
MattyNH
  • OWF Model: 7300E ; S-275
« Reply #14 on: December 20, 2013, 06:52:50 PM »
 I'm 98 feet from my house then another 28 feet in my basement to my oil boiler..
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
