Author Topic: Ridge wood vs Timberwolf  (Read 18629 times)
wissel12
  • OWF Model: 7500
« on: December 28, 2013, 05:24:26 AM »
Hello, I'm new to the forum. I'm going to buy a owb, narrowed it down to an ridge wood or timber wolf.  Would like to buy a wood master, but money is the issue.  Redoing and old farm house and spending money on a lot of different stuff in the house.
So give me your pros and cons on each.  Ridge wood guy said he would deliver it to me in ohio for free.
Thanks for your thoughts
Zack
03 Duramax 72000 Miles
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
Re: Ridge wood vs Timberwolf
« Reply #1 on: December 28, 2013, 06:31:15 AM »
If you want a woodmaster then a BurnRite out of mt pleasant michigan would be your closest match. If I had to pick between ridgewood and timberwolf I would say ridgewood. Some say ridgewoods are great and I've spoke to others that hate theirs.
Homerglide
  • OWF Brand: Orlan EKO
  • OWF Model: Out in the shop - Model 25 gasifier
« Reply #2 on: December 28, 2013, 06:37:40 AM »
Hello Zack:
I have not been up close to either of these units. There are very many Timberwolves in use near here. The RidgeWood is built not far from here and I was told that this outfit takes pride in their workmanship and uses decommissioned propane tanks for their firebox. That is a good thing as the steel is 3/8".
Coupla Chainsaws
Axe
Strong OLD Back
2000 Dodge Cummins
wissel12
  • OWF Model: 7500
« Reply #3 on: December 28, 2013, 07:50:30 AM »
Thank you both.
The big concern on the ridgewood is the legs it stands on.  I think they look weak.
Also the spray foam on both are concerning. But CB uses spray foam also
Thoughts on them issues?
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
andyhowardcity
« Reply #4 on: December 28, 2013, 08:47:42 AM »
I researched both stoves and ended up going with Timberwolf due to my insurance company requiring a UL listed stove.
I would say either stove is a good buy.  From what I have read and seen with my own eyes (I have been to both factories) both men that build these stoves are good, hardworking family men.
I have had lengthy conversations with both owners of their respective companies. I believe they are both putting out a quality product.
The Timberwolf's have a bit more of a track record as the company has been around longer.
I really don't see an issue with the spray foam failing.  It is amazing!  I also don't see replacement of the foam if it did fail as being a big issue at all.
The upside of both stoves is that they are very simple designs.  There is really not much that could go wrong and that is something that I like.
Timberwolf 5000 (Installed 9/2013)
Sidearm heat exchanger (in process of being installed)
20 cords of hardwood and 10 of soft ready to go :)
Stihl MS 362
Fiskars X27
wissel12
  • OWF Model: 7500
« Reply #5 on: December 28, 2013, 08:52:57 AM »
Thanks Andy
What do you think about the legs on the ridgewood?
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
chillyhiker
« Reply #6 on: December 28, 2013, 03:21:51 PM »
I have a ridgewood and am happy with it so far.The legs seem plenty strong it weighs around 1500 pounds.
stihl chain saws
husky spliter
 trailer for haulin wood.
andyhowardcity
« Reply #7 on: December 28, 2013, 05:57:28 PM »
The legs would not be a deal breaker for me.  The T-Wolf is on skids which made it nice to drag around.  I don't see the legs rusting out or failing on either unit.
Stihl MS 362
Fiskars X27
wissel12
  • OWF Model: 7500
« Reply #8 on: December 28, 2013, 07:01:26 PM »
Chillyhiker
 What size house are you heating? How long have you had the boiler.
I was think about getting the 7500
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
Speed
« Reply #9 on: December 29, 2013, 07:13:46 AM »
I have the Ridgewood 6000 and absolutely love it. It's been in operation for over a year now, as in all summer also, its never been shut down, and have zero complaints. I can't see why the legs would look weak? The unit itself is 1700lbs + 1300lbs of water =3000lbs. Its not going anywhere that I can see. It has had 70 mph winds shoving on it a few times. There are others that use spray foam, either kind of insulation have pros and cons, so it is what it is. There are a few threads on here about the Ridgewood you may want to spend the time to read. I think one is 8-9 pages lots of info in that one.
Speed
« Reply #10 on: December 29, 2013, 07:20:53 AM »
Wissel, just looked and that thread is on page 12 right now, lots of good reading, another member here, Scott7m is a dealer for them now also, he should be around if you need any info us users can't answer.
« Reply #11 on: December 29, 2013, 08:03:47 AM »
Weak legs?  far stronger legs than we have on some more expensive brands and they dont have issues
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
« Reply #12 on: December 29, 2013, 02:28:25 PM »
I have the ridgewood 6000 and love it.  Been in operation since August with no problem. Stove is very heavy duty and heats my 1680 Sq ft Ranch with unfinished basement  great.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
wissel12
  • OWF Model: 7500
« Reply #13 on: December 30, 2013, 07:37:32 AM »
Andy  The UL listing might be a hang up for me also. Insurance company requires it to be UL listed,
but does not require to see the paper.
What does everyone that has a ridgewood insurance company say about the UL?
Andy how  is the performance of your boiler ie burn time and sq/ft of house?
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
« Reply #14 on: December 30, 2013, 11:11:28 AM »
Why does the insurance company care if a non pressurized wood water heater installed outside with no exposure to a building to cause a fire is UL listed? Is it for insurance coverage in case the unit breaks down and they have to pay to replace it? Insurance company wouldn't care if you bought a commercial fire pit for your property and it wasn't UL listed. What am I missing here?
