Author Topic: Ranco question  (Read 6570 times)
Ranco question
« on: December 29, 2013, 12:11:49 PM »
My buddy has a Shaver 165 that we did the altheatingsolutions kit on that included new fan and soleniod plus a ranco aquastat. When we originally insalled everything and it worked flawlessly. In the past two weeks though the aquastat has not been reading accurately and shows a significant difference in temp compared to actual temp. Today it was showing 90* while the pipes and the aquastat inside showed actual temp of 150*. The temp probe is in the supplied drywell from the kit. The kit did not come with any cover to seal the end of the drywell but he put a cap on it that seals fairly well. Any ideas what the issue may be? Like I said it worked for about a month accurately.
AirForcePOL
  • OWF Model: G400
Re: Ranco question
« Reply #1 on: December 29, 2013, 12:14:48 PM »
Look at RSI's response to my question I just asked the other day in this section.   You probably need the conductive paste he mentioned.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
Re: Ranco question
« Reply #2 on: December 29, 2013, 01:39:23 PM »
I see the response. Looks like from my google search that it is mostly used in computer stuff. Any ideas where to buy locally?
« Last Edit: December 29, 2013, 01:46:14 PM by hondaracer2oo4 »
AirForcePOL
  • OWF Model: G400
Re: Ranco question
« Reply #3 on: December 29, 2013, 02:02:17 PM »
I searched on the Menards website and found it online.  That might not be the problem. Just a guess?
Athens, Illinois
Stihl MS 290
ITO
  • OWF Brand: HS1
  • OWF Model: 555
Re: Ranco question
« Reply #4 on: December 29, 2013, 05:34:14 PM »
 Not sure that conductive paste can make that big of a difference, I have two of these Rancos in dry wells and never used any paste with either of them, not saying it isn't a good idea but a 60 degree difference? Are you sure the connector for the sensor is plugged in all the way at the aquastat and not loose? I would also insulate over the dry well but if it was working for a month it sounds like a defective aquastat.
Re: Ranco question
« Reply #5 on: December 29, 2013, 07:02:51 PM »
I need to help him look it over. He just wanted to put the old water heater thermostat back on, I told him he was an idiot for thinking of doing that. I suppose that it could be a defective aquastat. If we can't find anything I'll have him call ranco.
Re: Ranco question
« Reply #6 on: December 29, 2013, 11:51:53 PM »
Is there any chance the probe got pulled out part way or the water level dropped below the dry well level?
If neither of these happened, I would pull the probe out of the well and put it in a cup of hot water to test if it is still working properly.
Re: Ranco question
« Reply #7 on: December 30, 2013, 10:59:50 AM »
I think he got it figured out. He pulled the probe and stuck it in a glass of hot water which was 1-2 degrees of the correct temp. What he realized while looking at the set up was that the bung that he had placed the well in was a six inch long 1 inch diameter pipe. The well is just a little smaller than that 1 inch pipe so only a small amount of water sits around the well. The six inch piece of pipe was also not insulated causing the water to cool down around the well causing a bad reading. We'll see if it fixes the problem.
Re: Ranco question
« Reply #8 on: December 30, 2013, 11:33:52 AM »
Yeah, that will do it.
If the well is made of copper, you may be able to cut it in the middle and add a section of pipe in to make it longer.
If that won't work, something like this might http://www.ebay.com/itm/THERMOWELL-304ss-1-2-FPT-x-9-L-x-1-2-MTP-281ER21-/200340213771?pt=LH_DefaultDomain_0&hash=item2ea535100b
