Author Topic: Opinions on insulating exposed pex in a basement?  (Read 20064 times)
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
« on: December 29, 2013, 04:40:35 PM »
Just curious where others are on this topic involving insulate or don't insulate exposed pex in basement. I insulated mine with some self seal foam wrap and noticed my wood usage went down from it. I can't say I ever noticed warmer floors when it was exposed in the basement so I figured insulating it wont catch all the heat rise.
Re: Opinions on insulating exposed pex in a basement?
« Reply #1 on: December 29, 2013, 04:56:47 PM »
I insulated all mine in the basement.
fireboss
« Reply #2 on: December 29, 2013, 05:21:45 PM »
I should because the room that the pex is under is so hot  but that is where my recliner is so I dont
JD Jim
« Reply #3 on: December 29, 2013, 05:23:50 PM »
I insulated all of mine, cause it goes thru the same small room the deep freezer is in.
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
« Reply #4 on: December 29, 2013, 06:31:38 PM »
Left mine uninsulated it heats up the floors nice.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
Trint
  • OWF Model: ml 30
« Reply #5 on: December 29, 2013, 06:57:17 PM »
insulated mine, the room got way to hot on the mild days
North Central Ohio
« Reply #6 on: December 29, 2013, 07:06:29 PM »
My pipes are uninsulated..keeps the basement warm and the upstairs floor warmer than if I had nothing in the basement…To me it helps heat the house
automan77
« Reply #7 on: December 29, 2013, 07:19:59 PM »
My basement stayed at 45 to 50 in the winter before I got my boiler and now it's 65 to 70
Scott K
Stihl ms 311
Husky 455
automan77
« Reply #8 on: December 29, 2013, 07:37:57 PM »
Not insulated.
Scott K
Stihl ms 311
Husky 455
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #9 on: December 29, 2013, 08:07:32 PM »
I have 4 lines of 1" Pex exposed for about 25' in my garage and they are not insulated. When the outside temps are in the teens, my garage stays in the 50's! If I ever install an exchanger in there, I will insulate them in order to be more precise in my heat delivery.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
MiHawkeye
  • OWF Brand: Heiss Heater
  • OWF Model: gasifier
« Reply #10 on: December 29, 2013, 09:11:10 PM »
I have my lines in my basement and garage insulated. Before I insulated them, my floors were very warm above them, but it wasn't in a good spot to be warm. The lines run right below my thermostat, and it would radiate through the floors and the hallway where the thermostat was running about 3 degrees above rest of the house. Not a huge difference, but enough to make my kitchen not pleasant on the very cold days. I also insulated the lines in my garage that runs to my garage hanging heater to reduce heat loss. I gained about 2 degrees on my return temps after insulating them. Once again, not a huge difference, but enough that it might help just that little bit.
AirForcePOL
  • OWF Model: G400
« Reply #11 on: December 29, 2013, 09:28:54 PM »
I insulated mine last year.   I would like to think I noticed a difference in my wood consumption but I really don't know.   I guess it's not really lost heat if it's going into your house.  I just wanted to retain as much heat as I could in the water lines so the air from my vents would be warmer.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
« Reply #12 on: December 30, 2013, 02:49:36 PM »
Insulate - help push the heat where you want it, I have a small mechanical room (PACKED under a stair well in Garage) before insulation it would get super hot; after insulation still above average but considerably warmer than rest of building.
P.S. In same cramped space is Hot water heater and pressure tank for well, so in winter time "Cold" water is 70F or warmer
BoilerHouse
  • OWF Brand: Home Built
« Reply #13 on: December 30, 2013, 03:03:31 PM »
For short runs insulation probably won't save any wood, but it will keep you from saying "darn thats hot" should you accidently touch the bare piping.
Muskoka, Ont
tawilson1152
  • OWF Model: 7300
« Reply #14 on: December 30, 2013, 04:27:13 PM »
Insulated, but installed a unit heater.
