Author Topic: Ball valve  (Read 9505 times)
mingom
Ball valve
« on: January 02, 2014, 05:13:33 PM »
Has anyone ever had an issue with a leaky ball valve at the handle? I know to tighten the pack nut but the one I have leaking doesn't have one. Any thoughts?
Jack72
  • OWF Model: E-1450 (11)
Re: Ball valve
« Reply #1 on: January 02, 2014, 05:48:38 PM »
That's about the only way to stop it from leaking tighten the packing nut if it's not there you may have to replace   Or you can do it the cheap way and dump some table salt on it you may get lucky and corrode up and stop maybe
Chevy 2500 HD 13 Duramax
Stihl 046 036 009
Northern Tool 25 ton Splitter
ecc_33
Re: Ball valve
« Reply #2 on: January 02, 2014, 05:49:50 PM »
Make sure its rated for decent psi. Some china made ones are known to be rated for .5 psi!
mingom
Re: Ball valve
« Reply #3 on: January 02, 2014, 06:01:44 PM »
I've got a new one ready to swap but it's -10 and the  valve is unfortunately the one ahead of my pump so I'll have to drain down to swap it
Jack72
Re: Ball valve
« Reply #4 on: January 02, 2014, 06:11:46 PM »
That won't be fun   Good luck
Stihl 046 036 009
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
Re: Ball valve
« Reply #5 on: January 03, 2014, 11:44:17 PM »
The legends don't have them packing nuts, and there's no fix. Don't think I've ever had one leak in 20 some years. If its a legend. I don't buy ball valves at the big box for this reason, those American valve brand are junk. Always leaking or the Teflon seal inside will be cut. Checkem on the shelf before you buy. Apollo is good but more coin.
Hint isolation flanges.....hahahahah
Michigan Thumber
mingom
Re: Ball valve
« Reply #6 on: January 04, 2014, 07:24:06 AM »
The new one I got is a nice apollo, but in regards to the isolation flanges - this is the ball valve to isolate the pump that is leaking, so unfortunately I don't have an isolation valve for the isolation valve haha.
Re: Ball valve
« Reply #7 on: January 05, 2014, 06:33:00 AM »
Oh come on it's only money, why wouldn't you have an isolation valve for your isolation valve?
martyinmi
Re: Ball valve
« Reply #8 on: January 05, 2014, 06:47:13 AM »
;D ;D That's funny Richard!!!!!!
Are you going to be at the farm show in Kentucky this year?
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
Re: Ball valve
« Reply #9 on: January 06, 2014, 06:30:08 AM »
I honestly don't know, it all depends on what Brian wants to do, I hope to, are you going?
martyinmi
Re: Ball valve
« Reply #10 on: January 06, 2014, 09:13:59 AM »
I plan on going.
I'll try and hook up with Scott7m too and make him buy me lunch!!! ;D ;D
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
Re: Ball valve
« Reply #11 on: January 06, 2014, 11:23:09 AM »
Heck maybe if we work on him together we could get him to buy us both lunch and adult beverages, now I really want to go!
