Author Topic: heatmor 200ss 1996 model  (Read 6566 times)
heat550
  • OWF Brand: Heatmor
« on: January 03, 2014, 01:13:38 AM »
I burned this heatmor for years. I don't know if its the wood I got oak 50% dried or what but if I do half fills with wood . load every 4 hours I go throw way less wood and water temp is higher more off cycles  . Has anyone else noticed this .  by the way this is at -20f also .  warmer outside temps I never noticed this . Ya we have had a cold snap for a week so I had a chance to try different things .  :thumbup:
Heat550
Re: heatmor 200ss 1996 model
« Reply #1 on: January 03, 2014, 11:15:08 AM »
Mine always seems to burn less wood and wind up with a cleaner firebox if I only fill it halfway or so and keep all of the wood directly over the grates with a clear ash tube.
heat550
« Reply #2 on: January 23, 2014, 01:40:28 AM »
Yes your right on the money . I got lucky this year I got 10 cord of 15-20% oak and wow talk about awesome heat output . I found out it was wet wood messing with me . Ya with dry wood and clean fire box the draft fan even cycles at -25 f think I even burned paint off chimney outlet :) Dry wood always fixes all the issues . Now I need to cut this spring because I think this load I bought was a blue moon event .  :thumbup:
heat550
ITO
  • OWF Brand: HS1
  • OWF Model: 555
« Reply #3 on: January 23, 2014, 06:35:55 AM »
 I have been trying this method too and I gotta say it works better. I have always had fairly dry oak but I didn't pay attention to cleaning out the ashes very often and I would load it to the gills. After reading Judd's post last January I gave it a try and it does produce good heat while using less wood, thanks.
