Author Topic: Placement of Boiler  (Read 8426 times)
wissel12
  • OWF Brand: Ridgewood
  • OWF Model: 7500
Placement of Boiler
« on: January 06, 2014, 06:29:50 PM »
I have a question.  With a natural draft do you face the boiler from cross winds.
I was thinking the cross winds would make the boiler over fire.
Any thoughts
03 Duramax 72000 Miles
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
Speed
  • OWF Model: 6000
Re: Placement of Boiler
« Reply #1 on: January 07, 2014, 04:07:48 PM »
My stove sits north - south. When I get a wind straight out of the west, which isn't that often, it actually seems to fire harder. Wind meaning 15 mph or more. Its almost like the wind is causing a vacuum and trying to suck air out of the draft door. But, it may just be in my head, too. Since my winter time prevailing winds are either south or northwest I don't worry about it to much. It has never caused it to over heat though.
wissel12
  • OWF Model: 7500
« Reply #2 on: January 07, 2014, 05:44:28 PM »
Thanks Speed.
The wind comes from the west. I was going to place the back facing the west.  There is a open field that is very windy.
I just thought it would get to much air.  So maybe facing the wind would be better.
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
baldwin racing
« Reply #3 on: January 07, 2014, 06:25:33 PM »
Thanks Speed.
if the back is facing west and you don't have a tall pipe its going to be blowing smoke in your face? just a thought...the only time you need to really worry is when your loading it.....with it facing the wind and you have heavy wind and flap open it could suck hot coals up exhaust also....and this will heat up your pipe very fast....I keep my door closed until I am ready to throw a piece in....then close door if I need to get more wood that's out of reach......I have seen my stack temp up to 600-700f when wind forcing in while door open and I am loading....but when I close door the stack limit switch has the damper closed and it cools to temp then opens back up.....this spring my indoor boiler will be in my shop when I add on.....right now its in a little building that's on the old boiler pad.... just some stuff to look into as well...you almost want the wind to blow cross ways or at a angle....
Kelly
husqvarna 357 xp
farmall H
MattyNH
  • OWF Model: 7300E ; S-275
« Reply #4 on: January 07, 2014, 07:02:02 PM »
Install it where the prevailing winds blow..
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
Speed
  • OWF Model: 6000
« Reply #5 on: January 08, 2014, 08:31:27 AM »
I would place the door facing the west in your circumstances. That will keep the wind to your back and smoke out of your face while loading.
wissel12
  • OWF Model: 7500
« Reply #6 on: January 08, 2014, 05:48:20 PM »
If the draft door stuck it would be bad?  How about front facing North?
And Speed(have you had a problem with the door sticking open?
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
