Author Topic: anyone ever add insulation to there owb?  (Read 10259 times)
hpowers
  • OWF Brand: Tennessee Outdoor
  • OWF Model: Hoss 400
« on: January 09, 2014, 05:42:55 AM »
just wondering I have about 10" where I think I could add some, any thoughts
Stihl- 310,180,441,261,271
Huske 28 ton splitter
IH 826
Honda Foreman
And 4 kids to help
chevy 2500 hd
lindnova
  • OWF Brand: Heatmor
  • OWF Model: 200 CSS
Re: anyone ever add insulation to there owb?
« Reply #1 on: January 09, 2014, 07:00:24 AM »
I added about 8" to the top and foil bubble type on the outside doors of my Heatmor 200.  I was loosing too much heat on windy days.  Seems to help some.  The roof insulation had gaps between the batts and pretty sloppy.  I only added as much as would fit and didn't try to pack it in there tight.  The wrap on the doors helps as those thin doors leak a lot of heat - especially the back door facing the west wind.
Stihl ms260, ms362, msS461
Huskee 22 TN Splitter
Kubota BX2200 w/ Loader
willowbk
  • OWF Brand: port/main
  • OWF Model: 250
« Reply #2 on: January 09, 2014, 07:06:27 AM »
i just cut to fit 2" foam board from lowes around base of unit to keep wind and cold out and away from pipes coming up out of ground, figured it couldnt hurt, keeps critters out and not hot enough to cause melt issues. stopping any heat loss has to be a bonus for couple $$ investment.
redthunder
  • OWF Brand: hoss 400 he
  • OWF Model: hoss
« Reply #3 on: January 09, 2014, 02:05:43 PM »
is that on top of the hoss I have the same stove what are burn times you are getting
mikemike
  • OWF Brand: home made
« Reply #4 on: January 09, 2014, 04:09:35 PM »
I would think the more the merrier insulation must be cheaper than wood
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
« Reply #5 on: January 09, 2014, 04:56:20 PM »
My stove was neatly wrapped in r30 and I added r19 until it was snug to the bottom,sides and top. Helps so much to where running a 15 diff in 30 degree weather my fire almost dies out.
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« Reply #6 on: January 10, 2014, 02:08:14 PM »
I've done many , using Roxul. Actually helps a lot for standby loss. Doesn't loose it R value like pink does when it gets wet,damp or compressed.
Michigan Thumber
