Author Topic: How can I increase Ph level  (Read 8489 times)
3roofmen
  • OWF Brand: homemade
« on: January 19, 2014, 02:28:21 PM »
I have a homemade outdoor furnace that holds approx. 280 gallons water. The PPM level is around 800 but my PH level is only 6.5. Can I increase the PH level with baking soda and not counter act my PPM level? Thanks Michael
BoilerHouse
  • OWF Brand: Home Built
Re: How can I increase Ph level
« Reply #1 on: January 19, 2014, 04:51:17 PM »
Baking Soda (sodium bicarbonate) shouldn't affect nitrite levels.  I would probably recommend concentrated sodium hydroxide (lye) if you can get it.  It is commonly used alongside nitrite as a corrosion inhibitor. It's nasty stuff and a little goes a long way.  Start with a few tablespoons and work up from there to avoid over dosing.  Aim for a pH around 8.5.
Muskoka, Ont
ITO
  • OWF Brand: HS1
  • OWF Model: 555
« Reply #2 on: January 19, 2014, 05:05:16 PM »
 Pool supply has ph increaser, so does Menards, lowes or similar.
3roofmen
« Reply #3 on: January 20, 2014, 04:08:31 AM »
thanks for the info guys :)
« Reply #4 on: January 20, 2014, 03:36:45 PM »
Most companies are happy with ph results in the 8.5-11 range
3roofmen
« Reply #5 on: January 20, 2014, 09:26:55 PM »
ok thanks
allis48
  • OWF Brand: natures comfort
  • OWF Model: ncb250
« Reply #6 on: January 22, 2014, 06:28:24 AM »
How can I lower my Ph mine is over 11
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #7 on: January 22, 2014, 06:30:25 AM »
Same place Mr. ITO mentioned.  Pool supply stores make a product called "spa down" or "ph reducer" or things like that.  There are instructions on the bottle as to the dilution requirements.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
