Author Topic: Pump impeller failure  (Read 3108 times)
clydem
  • OWF Model: 5036
« on: January 20, 2014, 08:30:47 PM »
A friend of mine has a CB5036 about 8 years old sent me this picture of his original pump. Any idea what caused it to fail ?   How many years should the impeller be good for & how often should it be inspected?
thanks
see picture in my album
« Last Edit: January 20, 2014, 08:58:31 PM by clydem »
CB5036    inst: 11/20/11
JD 4600,  G27 IWB
Re: Pump impeller failure
« Reply #1 on: February 19, 2014, 01:38:07 PM »
I am no pump expert, but I would guess that only three thing could affect the impellar;
  Heat
  Debris
  Chemical
 ** forgot age
Since you made no mention of rocks or chunks of stuff coming out of lines when taken apart, I would guess that just normal wear and tear took its toll
« Last Edit: February 19, 2014, 01:40:47 PM by LittleJohn »
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« Reply #2 on: February 20, 2014, 08:35:46 PM »
How is the circ installed? Does it feed the top or bottom side of a header? Or is it just inline of one big loop. .has debris been checked for in the bottom of boiler? I'm gonna take pics of the almost full 5 gallon bucket I cleaned out on the Sprinter right now.
That appears to be chemical degradation, just like high chloride levels.
« Last Edit: February 20, 2014, 08:37:52 PM by Sprinter »
Michigan Thumber
