Author Topic: Temperature monitoring.  (Read 10241 times)
Grjfer
  • OWF Model: H2
« on: January 22, 2014, 11:53:26 AM »
Hello all. First time poster with a Hardy H2. I am looking for options on remote temperature monitoring. All I wasn't too do is have the ability to monitor high/low temp at the OWB. In the event of low temp such as fire out, or high temp because of a stuck flapper or door open. I have looked at the digital readout that RSI sells as well as a wireless BBQ monitor. Abby and all suggestions welcome.
muffin
Re: Temperature monitoring.
« Reply #1 on: January 31, 2014, 11:36:37 AM »
I have the BBQ monitor and love it.  The alarms work great and warn of both the events you discussed.  And it is really cheap.
Grjfer
  • OWF Model: H2
« Reply #2 on: January 31, 2014, 12:31:24 PM »
Muffin, thanks for the input. Are you using the single prob model or dual prob?
muffin
« Reply #3 on: February 05, 2014, 08:13:31 AM »
Dual probe.  One on supply and one on return.  The return is fun to watch and does tell you something about your system efficiency.  With nothing calling for heat, it should be close to the supply.
Grjfer
  • OWF Model: H2
« Reply #4 on: February 09, 2014, 07:45:21 PM »
Ordered the Maverick ET732. Should be here in a few days.
willowbk
  • OWF Brand: port/main
  • OWF Model: 250
« Reply #5 on: February 12, 2014, 05:47:24 AM »
can you tell me how they work, i see there are 2 probes and 2 monitors, 1 small 1 bigger.
i'm about 225 ft from house to owf.  thanks
« Reply #6 on: February 12, 2014, 09:16:40 AM »
I have the ET-73 model. I have used it for 3 years now with great results. My remote probes are not out at the boiler but rather on each side of the heat exchanger so that I can monitor what the temp is before it goes through the hx and after it goes through. The temp on the incoming side is about 1 degree below the temps at the boiler with my set up. I don't see any reason to place it actually out at the boiler.
Grjfer
  • OWF Model: H2
« Reply #7 on: February 12, 2014, 09:42:55 AM »
The reason I want it at the OWB is to monitor high/low temp conditions. Not sure placing it at the heat exchanger would give me enough warning time of a boil over or fire out condition.
bajonesy77
  • OWF Brand: Prosteel
  • OWF Model: 200
« Reply #8 on: February 12, 2014, 01:22:38 PM »
Unless your lines between house and owf lose a lot of temp. Shouldn't be but a few degrees difference.
Brave 22 ton splitter
Stihl 440 magnum 20" bar
Stihl 390 20" bar
McCullough timber bear 20" bar
willowbk
  • OWF Model: 250
« Reply #9 on: February 12, 2014, 04:25:17 PM »
can you guys tell me where the probes go, i'm assuming you just strap them to somewhere convient on supply or return lines.  does it matter copper or pex.
Sluggo
  • OWF Brand: Heatmaster SS
  • OWF Model: 20,000e
« Reply #10 on: February 13, 2014, 05:48:11 PM »
Your going to get a much better reading off from a metal pipe as opposed to Pex.  Put it where it's convenient and simply compensate for heat loss on any alarms you set.  Say if your probe reads 165 entering the house but your stove is at 175 then just set your alarm 10 degrees off.
Stihl 441
Stihl 660
Stihl 029 Farm Boss
Bobcat T190
Grapple
Farmi 501 Winch
2015 3500 Crew Cab HIGH COUNTRY Duramax
stewie3500
  • OWF Model: C375
« Reply #11 on: February 13, 2014, 07:48:08 PM »
I also use the maveric et-73. It works well. To get the most accurate reading with the probe located on pex I have placed a layer of foil tape on the pex the length of the probe then a layer of foil tape over the probe. The foil helps to conduct the heat into the probe by increasing the surface area for heat transfer. After the foil tape I use split pipe insulation and then wrap the whole area with foil backed insulation..it appears bulky but works well for me.
Ram 4500 C&C
Load Trail 14k dump trailer
Kubota m6060
Stihl MS 660
Stihl MS 460
Stihl MS 261
Stihl 08s
