Author Topic: My project  (Read 26535 times)
My project
« on: January 24, 2014, 04:32:14 PM »
Well, ive been involved with a lot of aspects of this business but im going to build a couple stoves just for the heck of it.
Ill go over some of my specs.
Firebox is gonna be 32"x32" cold rolled steel 1/4" thick.
Water jacket is going to be 38"x44" 3/16" cold rolled steel, pretty much industry standard.
Water capacity is going to be 105 gallons.
Using 2x2 framing for the boiler, front plate is 1/4", rear plate is 3/16"
Its going to be forced draft through the door with no ash pan.  Its going to have a drop chimney that comes down to within 12" of bottom of firebox.  Going to be wrapped with 6" of fiberglass insulation with a wrap or prodex around that.
Is it going to be the most efficient stove?  No, but it will be just as good as the rest of the conventional stoves out there.
Steel is already in, we'll start welding onfce our garage warms up above 0 lol
Ill post some pics as we go....
skorpyd
  • OWF Brand: Home Built
Re: My project
« Reply #1 on: January 24, 2014, 04:54:15 PM »
Sounds interesting Scott,  pics of progress sounds great.
Is firebox and water jacket going to be square or round or something in between.
What is prodex, please.
Re: My project
« Reply #2 on: January 24, 2014, 08:26:42 PM »
Cold rolled steel, round firebox and water jacket
Prodex is a closed cell foam wrap about 1/4" thick, has foil on 2 sides, advertised as r16
Re: My project
« Reply #3 on: January 24, 2014, 09:40:38 PM »
Scott, can't wait to see the build !  I know it would be slightly more complicated but why not try to send that flue for at least one pass through the water jacket?
Re: My project
« Reply #4 on: January 24, 2014, 09:48:47 PM »
With the 3/16" will the water jacket sides be self supporting or will they need bracing of some sort to keep from bowing out from the weight of the water?
I used 3"x1/4" on the outsides of my water jacket 1/3 and 2/3's on welded on the outside of the jacket to prevent bowing, then placed an insulator on top of the flat iron then bolted 2"x2"'s to the insulator so I could fasten the metal to that.
I'm wanting to say I used 8 gauge for the water jacket sides, 1/8" for the top and 1/4" plate for the bottom.
Re: My project
« Reply #5 on: January 24, 2014, 09:56:17 PM »
Your water jacket aint round?
These will be round, there not gonna budge.  Its industry standard to use 3/16
Some companies use much thinner, earth uses a material aroind 1/8 inch and hardy uses 1/16 inch firebox and water jafket
Re: My project
« Reply #6 on: January 25, 2014, 06:05:25 AM »
Nope, first one I build was a close clone of the Central Boiler, next one will be of the P&M Optimizer 350 but don't tell anyone.
Re: My project
« Reply #7 on: January 25, 2014, 06:15:53 AM »
Scott - Knowing how the EPA has a hair across it's azz about conventional OWB's, their overall disdain for them and the "pollution" (their word, not mine) they put out, out of curiosity, why not try to improve on a gasser design?  I'm simply curious, that's all.  Oh, good luck with the build.  Roger
Re: My project
« Reply #8 on: January 25, 2014, 10:12:29 AM »
I might try that at some point.  But generally speaking  the fact that "they" dont like it, makes me wanna build what they dont like even more lol
I feel as humans more of us need to answer to our own moral compass vs what the govt tells us too!  Ive seen and heard so much pointless regulation my head is about to pop off, its all non sense.
This could turn into 20 pages followed by 20 pages of historical info that drives me to feel that way
But in regards to a gasser, just for fun I may take a design I like and try to build upon it at some point, keep in mind though companies like central, empyre, heatmaster, p and m, all spends hundreds of thousands in testing and tweaking these.  Some of those still leave a LOT to be desired.
When I build a gasser it will be a highly insulated firebox with a lot of refractory with a seperate heat exchange system for transferring it to the water;  essentially a dry firebox design.
A design like this would be great but I dont see it as feasible for production due to cost of doing it this way
mikemike
  • OWF Brand: home made
Re: My project
« Reply #9 on: January 27, 2014, 03:28:30 PM »
Come on Scott! Anyone can build one of them. How about steppin it up a notch? I'm thinkin a conventional with a dry fire box. Dare to be different. LOL
ms1780
Re: My project
« Reply #10 on: January 29, 2014, 01:54:16 AM »
Scott, can you share where you purchased your steel from?  I am getting ready to start a build and don't really care to cut propane tanks if I can avoid it.
Re: My project
« Reply #11 on: January 30, 2014, 10:23:15 PM »
Huntington Steel
New, not rusty, good looking product and fit and finish was nive
WoodMOJoe
Re: My project
« Reply #12 on: January 31, 2014, 05:52:06 AM »
Hey cutting propane tanks is fun!   >:D
I bought my face/door opening plate (5/16") from Ozark Mountain Steel on W. Chestnut St in Springfield.
They can cut and supply anything you may need but new steel is expensive.
fryedaddy
  • OWF Model: 750 Gallon
Re: My project
« Reply #13 on: January 31, 2014, 11:45:06 AM »
Have you thought about running the flue horizontal instead of vertical?
You would be able to add a back box and the rain wouldn't be able to go directly into the firebox.
Just a thought.
Re: My project
« Reply #14 on: January 31, 2014, 12:06:33 PM »
Yeah but you really don't want  to start with rusty steel either considering rust is the bane of owb.
« Last Edit: January 31, 2014, 04:36:31 PM by mlappin »
