Author Topic: Woodmaster 4400 Baffle Rod Broke  (Read 10198 times)
terpjr
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« on: January 24, 2014, 07:55:31 PM »
Hi guys,
Went out tonight, opened the chimney baffle on my 4400 and the rood kept pulling.  It appears the that the pin that holds it to the plate is b roke.  I think it is stuck in the closed position as I am getting hammered with smoke when the door is open.
Has anyone else encountered this problem?  What is the process to fix it?  It is dark and the fire was cookin' so it is not something I was going to tackle tonight but I would like to fix it asap as I come in the house smelling like I have a three pack a day habit.
Thanks!
Steve Terplak - Upstate NY
Woodmaster 4400
Husqvarna 562xp, 460 and 261
Massey Ferguson 165, 265, 1080, 40B backhoe, Landini 105 and JD 450B dozer.
Homemade 3pt hitch splitter.
PhinPhan
  • OWF Brand: WoodMaster
  • OWF Model: 4400
    • Outdoor Wood Furnace Info
Re: Woodmaster 4400 Baffle Rod Broke
« Reply #1 on: February 14, 2014, 02:41:20 PM »
Hey Steve,
Mine did the same thing.  Have you fixed it yet?  I ended up calling woodmaster and ask them about it, they guy I talked to said it is a 5/16 x 2 stainless steel bolt that hold them together.  I just have mine pushed all the way back right now.  He said in order to fix you have to climb in the firebox and manually slide out the plate and he said it is a slow process, then bolt it back onto the rod.
Let me know if you do this or if you have already done it, I'll be curious how it went.
Pomeroy, OH
WoodMaster 4400
sceptre74
  • OWF Model: BL 28-40
« Reply #2 on: February 14, 2014, 02:50:25 PM »
« Reply #3 on: February 14, 2014, 03:02:49 PM »
It's not hard to do just nasty and hot if the fire is still going, trust me , been there, best to run it till spring if you can't shut it down and it won't hurt a thing.
