Author Topic: OWB Making Too Much Charcoal ?  (Read 19474 times)
skorpyd
  • OWF Brand: Home Built
« on: January 25, 2014, 11:10:25 AM »
My home built OWB (can be seen on Home Made section) has been online for a week now.  It has been very cold here and I'm very thankful to not be using propane.   I have been using lots of wood though, and it seems to not be burning the wood completely.   I have filled it up almost to the door with small chunks of basically charcoal.
One day this week I got home from work and the wood I had put in before work was gone, and the bed of coals left was not burning.  The temps were way down.  100 degree coming back to unit and about 120 coming out.
The blower fan was on but the coals were not lit up.
I purchased a commercially made door from Burnrite with the integrated blower so I figured this would be a good set up.   One thing I did yesterday was to install a diverter on the lower blower exits, thinking that shooting the air more downward into the fire would help.
It was inconclusive as I put wood in this morning at 4:00am and at 11:00am most of the wood was gone and the temps were starting to come down at the boiler.
I then left the door open slightly where the fan was blowing onto the coals and getting more air into the unit with the open door.  The coals started to light up and the temps also started coming up .
So I guess that is telling me it's not getting enough air.    I'm just wondering what some of you veteran users have to say about it.   I was expecting to burn the coals down to a fine ash but so far thats not happening.
The blower only has about a 2" diameter exit coming out of it so maybe I need a bigger one.   I also have a 6" flue pipe.  Blower model is a Fasco model 50748-D500.
jerkash
  • OWF Brand: Legend
Re: OWB Making Too Much Charcoal ?
« Reply #1 on: January 25, 2014, 04:07:35 PM »
How far below the opening is the bottom of the firebox?
skorpyd
« Reply #2 on: January 25, 2014, 05:03:19 PM »
I would say 10-12 inches.   Basically what the square frame of the door versus the round opening of the firebox made reasonable.
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
« Reply #3 on: January 25, 2014, 06:25:27 PM »
I have a burnrite 228 and it has a 8 inch chimney. Is your chimney plugged? What temps you running? I wonder if you should cut away some more of your chimney pipe that comes down into the firebox. Those are 100cfm fans and mine does fine for draft but i have a baffle design so maybe thats the draft difference.
woodman
  • OWF Brand: hawken
  • OWF Model: he1000
« Reply #4 on: January 25, 2014, 06:34:16 PM »
It looks like you need less wood and more air. I just checked, my blower is rated at 146 cfm, not sure how that compares to your blower.
victor6deep
  • OWF Model: 228
« Reply #5 on: January 25, 2014, 06:41:37 PM »
It just looks like you need more air space for heat to get up and out that chimney.
« Reply #6 on: January 25, 2014, 07:23:50 PM »
any way to get the blown air under the wood?
« Reply #7 on: January 25, 2014, 07:32:39 PM »
You need to shoot that air into the coal bed. It looks like it shoots it straight 45 degrees up into the firebox. You need to fan those coals hard with the blower. I don't know how burnrite builds there opening compared with their door but I would guess that it is much different then yours. I would weld on another piece of 2x2 box or whatever that nozzle is and shoot the air down into the coal bed. You should burn everything up then.
« Reply #8 on: January 25, 2014, 09:12:19 PM »
It looks like Burnrite has the exhaust exit the front of the firebox. With your setup you are blowing the air straight to the chimney.
Is there any chance you can move the blower to the ash door? If not, I think you will need to try keeping a larger pile of wood in the center of the firebox. You need to air to pass through the fire before it gets to the chimney.
jerkash
  • OWF Brand: Legend
« Reply #9 on: January 26, 2014, 04:04:03 AM »
As others have stated, you got to get that air at the bottom of the coals - You seem to be blowing it right over top of them.
skorpyd
« Reply #10 on: January 26, 2014, 04:29:00 AM »
Thanks for the thoughts guys,
Just to clarify,  the model of fan that I have is only 65 cfm with a slightly more than 2" exit diameter from the blower.
The air supply/exhaust into fire box has 3 openings, the square one in the pic that blows right towards the flue opening and basically over the fire and then there are 2 on the bottom that are about 3/4"x3" pointing straight out from the bottom of the door frame.
I added the bent piece of steel to try to deflect air from those bottom ports more towards the bottom of firebox/ashes.
I have found a 130 cfm Dayton blower that will fit into the existing box with it looks like only small modification.  So I'm thinking of trying that.
Maybe covering that top exhaust port to direct all or most of the air more downward would help also. I'm wondering though if I would be constricting my blower too much.   Right now though it does not feel like there is a very high velocity of air coming out when the fan is on.
If the flue is not large enough then that would be major and I would just have to live with making charcoal.
I have thought about facing the opening in the flue towards the back.  That would in effect be making the smoke go through 3 90 degree turns to get out.   I don't know if that would make things better or worse though.
Using the ash door for combustion air is doable.  It just means redoing the whole air supply system,  so I am hoping to find an easier fix first.   It would have to be an off season project.
« Reply #11 on: January 26, 2014, 06:36:39 AM »
OHHH I see the lower ports for air now. If it were me the first thing I would do is try occluding that top square piece that just shoots air over the fire forcing all of your air to shoot into the coal bed. After that I would go with a bigger fan if that doesn't help. Plenty of units with in door fans so it should work ok for you with some tweaks. Just need to get that air into the coal bed instead of up high. Your flue size is fine, it is much more important when you have a natural draft stove to have the flue size correct. Shaver uses a 5 inch flue and they are very similar to yours.
« Last Edit: January 26, 2014, 06:48:31 AM by hondaracer2oo4 »
dukethebeagle
  • OWF Model: 0001 hot tamali
« Reply #12 on: January 26, 2014, 06:42:17 AM »
 to me,on the pic the angle of the air going into the firebox looks like it would be blowing to the top of the firebox.
if it was mine i`d take the door off and just weld either a small flat plate or maybe a piece of channel say 2`` long just to help divert the air down to the fire. to me you air intake is o.k just your angle to the fire is off.like someone else said ,your blowing right over the coal.
      good luck
austin qc
bluegrass rules
proud appalachian
skorpyd
« Reply #13 on: January 26, 2014, 07:03:03 AM »
I just covered the square opening on top to divert air to lower openings.   We'll see how it goes.
« Reply #14 on: January 26, 2014, 08:05:00 AM »
Let us know. I think it will help a lot. Your fan is pretty small so you may need an upgrade but worth a shot first.
