Pages: 1 ... 16 17 [18] 19 20 ... 33
Author Topic: new heatmor and having huge issues  (Read 262513 times)
Re: new heatmor and having huge issues
« Reply #255 on: February 27, 2014, 09:38:22 AM »
Yes but it is probably not a good time to do it with the cold snap on.
kipk
  • OWF Brand: Heatmor
  • OWF Model: SSRII
« Reply #256 on: March 01, 2014, 11:54:35 AM »
Just ran across this thread, and felt compelled to share my experiences.  I purchased a SSRII this fall also and had a similar issue.  My dealer was also not available, but due to a life threating accident that placed him in the hospital for much of the beginning of the winter.
I too had tons of creosote buildup in the first few days, poor temperature control, and an unbelievable appetite for wood.  (~4 full loads per day).  It was a very cold week when I started the furnace (first day was January 3), so I didn't know if I was really burning too much wood, but I knew something was very wrong.
What I found in mine furnace was that the controller was set to the factory default settings for the controller, not the settings that Heatmor selects we configuring the furnace.  The nameplate on my furnace says it was built in 2011, so I wouldn't be surprised if the controller settings reverted back to original, depending on the memory storage type, after being turned off for 2 years.  The induction blower was running between 159 and 185 degrees.  I got the blow-off from Heatmor down to the distributor despite my situation.  The distributor had me call the rep for another area, which had no experience with the SSRII, but did his best, and got me what I needed.
Took a few days, but Mike @ Heatmor sent the password and settings page down the chain to me, which corrected my problems.  To be fair, as an controls/electric engineer, I was able to identify the problem with the controls despite having no experience with the furnace, which I wouldn't expect from most people.  Heatmor really needs to do better support in a situation like this, as they have assumed liability for it when they don't provide better data in the manuals other than "leave the controller alone".
I also have entirely new install (all DIY), not just furnace which leaves _many_ variables open.  I'm currently running a large forced air heater in the basement to heat an old farmhouse, until I get the radiant floor finished before next season.  But now that the kerosene heater is retired and the bill for the electric heat has dropped ;D, I know that the furnace was the right choice.
I was very disappointed with the fact that Heatmor and the distributor seemed like they didn't want to deal directly with customers at all, especially new ones that are need support on a furnace under warranty.  Time will tell for me if the furnace quality will make the support issues worth enduring.
Roxann, I feel your frustration.  But once you get the bugs worked out, you'll find that the furnace works much predictably, and much less  :bash:
Kip
roxann
  • OWF Brand: heatermor
  • OWF Model: 200ssr11
« Reply #257 on: March 01, 2014, 05:06:14 PM »
You know its cold in your house when your cat is sleeping on the baseboard lol
« Reply #258 on: March 01, 2014, 07:38:38 PM »
 We found the problem! The cat is insulating the baseboard and not allowing the heat out into the house.  ;D
roxann
« Reply #259 on: March 02, 2014, 05:57:23 AM »
I woke her up trying to take this photo....
Slim thanks for calling last night.. You gave me some good pointers
Thank you for all your help and pointing me in the right direction I really appreciate your help and kindness
« Reply #260 on: March 02, 2014, 06:01:14 AM »
  You are very welcome, have Rick call me for better heat control if you like, I will be here all day if you can get down to pick up that slide hammer, bring your old one with you so we can make any necessary adjustments here, call first.
roxann
« Reply #261 on: March 02, 2014, 06:11:35 AM »
Kikp
we share about the same story...
Slim has adjusted my low and high limit they were set  backwards
I also am going to put  radiant floor in the basement this year. I am hoping it's going to be a big help!!!
Slim is going to talk to my installer about adding more zones and baseboard
it's mild out today and my home is warm I got up at 4 am the unit temp was 164  red hot coals  and 67 in house
today is flue cleaning yahoo
I hope the wood flow slows down I am using about 2 cords a month is thisa normal use??????
« Reply #262 on: March 02, 2014, 06:33:20 AM »
It all depends on your btu load requirements Roxann. Wood has so many btus per cord. For comparison I too burn 1 cord every two weeks or 2 cords per month on average.
« Reply #263 on: March 02, 2014, 03:48:59 PM »
I'd be happy with two cords a month given the winter we've had. Unfortunately though for two cords a month you're house should be toasty. Ours is set at 72 all winter.
roxann
« Reply #264 on: March 02, 2014, 05:18:41 PM »
I'm glad that others are burning as much as me.... I wish my house was toasty all the time though
roxann
« Reply #265 on: March 02, 2014, 05:20:16 PM »
slim I will be leaving my house at 7.30 should be to you around 9 sound ok
kipk
  • OWF Model: SSRII
« Reply #266 on: March 02, 2014, 05:23:31 PM »
Roxann,
To be honest, I have no idea how much I have used this winter.  Definitely more than I was prepared for, but I knew that, just didn't have the time to get ready for the winter.  I've been burning a lot of green wood (ran out of the dry stuff), so next winter should be much better.
I had a green load delivered (tri-axle boom truck) and haven't even used half.  Best guess of what I've used so far would be 3-4 cords.
« Reply #267 on: March 05, 2014, 06:26:11 AM »
 Can't imagine 2 cords per month.
If the heat isn't being wasted iit will take even more wood once the btu issue inside the home is fixed.   It just seems like the boiler now is always up to temp but never the home which shows the boiler isn't getting much of a work out.
Probably need more radiant inside the home to make it work well.
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« Reply #268 on: March 05, 2014, 08:28:18 AM »
Wow, lots of wood for that size house. Any idea on what kinda degree days you area has?
Has anyone checked supply and return zone temps to see what's actually each zone is doing
Michigan Thumber
roxann
« Reply #269 on: March 05, 2014, 02:02:49 PM »
the temp on stove this morning was 181 house was 59 brrrrrrrr no over heating and fan is shutting off seams like the unit is working now got to get heat in the house
I am working on more radiant
I also thought that was allot of wood to burn
the weather is below 0, 20's teens mostly over night is my issue on the first floor keeping it warm
