Author Topic: material for water jacket and firebox  (Read 10259 times)
ms1780
« on: January 29, 2014, 03:47:12 PM »
I am having trouble finding a suitable setup for a firebox and water jacket. I can get two propane tanks. One is a 30" and the other a 38" but that doesn't give me much water capacity.  My other thought was to use the 38" one for my fire box and build a square water jacket from 1/4" plate. My third option is to use the smaller 30" propane ta k inside a 300 gallon farm fuel tank. I already have the farm tank so this would be the cheapest for me. I have read that several manufactures only use an 1/8" inch water jacket. Can I get your opinions please.
Thanks,
Mike
BoilerHouse
  • OWF Brand: Home Built
Re: material for water jacket and firebox
« Reply #1 on: January 29, 2014, 05:53:49 PM »
My water jacket is 1/8.   The firebox is heavier.  I believe there is a lot more stress in the firebox than the water jacket.
Muskoka, Ont
ms1780
« Reply #2 on: January 29, 2014, 08:23:11 PM »
Thanks boiler house. I hate to buy something when I have that tank. If I do end up using it I will frame it with some light channel or something to strengthen it.
« Reply #3 on: January 30, 2014, 07:28:02 AM »
Mine's 1/8" as well, no rust thru since building it over a decade ago. You're on the right track as well as it will need some reinforcement to keep from bowing out.
« Reply #4 on: January 30, 2014, 09:52:59 AM »
Think about this guys, if you are building your own boiler, why not think about a sacrificial dry firebox
« Reply #5 on: January 30, 2014, 01:17:58 PM »
I've seen something similar once, guy uses a forklift to load it with LOGS, exhausts out the back to a secondary heat exchanger to heat the water. Think he built the firebox out of a used dumpster.
