Author Topic: Water heater ?  (Read 14715 times)
12valve
  • OWF Brand: P&M
  • OWF Model: BL-3444
Water heater ?
« on: February 06, 2014, 08:42:17 AM »
Hey all.  So the last thing in my house that sips propane is my hot water heater, and thats only in the summer.  I have to fire up my old in efficent boiler just to have hot water.  I have a boier mate hot water system which workds great when the OWB is fired so i dont want to rip that out.  I would like to get ride of the propane all together, I dont want to fire the OWB all summer so for a few months I would just like electric hot water.
Any suggestions?  I was thinking of plumbing in a electric hot water heater on a ball ball valve, so I would use the boiler mate when OWB was fired and switch over to electric in the summer.  Are there any other suggestions any one can think of?
Re: Water heater ?
« Reply #1 on: February 06, 2014, 08:57:14 AM »
Have you thought about an electric on demand wall hung boiler for you domestic
12valve
  • OWF Brand: P&M
Re: Water heater ?
« Reply #2 on: February 06, 2014, 09:04:26 AM »
NO SlimJim I hadn't.  I guess I knew they made those with Propane but I was not aware of an electric one.  I will look into that.
Re: Water heater ?
« Reply #3 on: February 06, 2014, 09:07:08 AM »
I have never used one but they use a lot of them in Canada as power is so cheap there
12valve
  • OWF Brand: P&M
Re: Water heater ?
« Reply #4 on: February 06, 2014, 09:13:54 AM »
Anyone have one.  My summertime load should not be to heavy.  whats a good brand?
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
Re: Water heater ?
« Reply #5 on: February 06, 2014, 09:38:54 AM »
Hard to pick out sarcasm on the internet Slim. I believe WillieG calculated his power to be almost 21 cents/kwh. ( total bill/kwh used = 20.52 cents/kwh on my last bill)
Rates are cheaper across the rest of the country compared to Ontario.
Re: Water heater ?
« Reply #6 on: February 06, 2014, 09:44:44 AM »
I know on demand water heaters are frowned upon down here.
I have heard of a few customers complaining about them burning up and not saving much
Id go with a simple regular style or perhaps a hybrid model..     Hybrid meaning heat pump style water heater
ITO
  • OWF Brand: HS1
  • OWF Model: 555
Re: Water heater ?
« Reply #7 on: February 06, 2014, 09:56:59 AM »
 Don't know where you are at but solar panels seems a great choice for summertime use if you can make that work, you have the storage tank already.
Re: Water heater ?
« Reply #8 on: February 06, 2014, 10:44:42 AM »
Get an add on DHW heatpump and connect it to the boilermate. If you use a lot of hot water you may need to add an electric heater too or set it up so it runs more and store heat in the OWB.
Re: Water heater ?
« Reply #9 on: February 06, 2014, 11:33:07 AM »
Ouch, I'm paying a tad over 10 cents a kilowatt. The wifes family in England pay about 3-4 times what I do for a kilowatt.
12valve
  • OWF Brand: P&M
Re: Water heater ?
« Reply #10 on: February 06, 2014, 12:35:14 PM »
Thanks for all the advice.  I have a little research to do/.
12valve
  • OWF Brand: P&M
Re: Water heater ?
« Reply #11 on: February 06, 2014, 01:13:08 PM »
OK Guys I like the idea of the heat pump which I had never heard of.  I did some research, one, I cant find one that hooks in with a boiler mate?  RSI do you know of any.  The other thing is they seem pricey and I will only be using for aprox 4-5 months a year.  That puts me back to traditonal or on demand electric.
Re: Water heater ?
« Reply #12 on: February 06, 2014, 01:15:54 PM »
This one is about $350 on ebay. Hot and Cold: Heat Pump Water Heater
Re: Water heater ?
« Reply #13 on: February 06, 2014, 01:19:29 PM »
You could also use something like this http://www.ebay.com/itm/AirTap-A7-water-heater-Add-on-heat-pump-energy-saver-local-pickup-only-/111233077833?pt=LH_DefaultDomain_0&hash=item19e6021249
With this one you need to have a fitting in the top of the tank to insert the hot coil into. If you don't have any available, I don't see any reason you couldn't just use a section of pipe and pump water through it to your tank.
12valve
  • OWF Brand: P&M
Re: Water heater ?
« Reply #14 on: February 06, 2014, 02:00:14 PM »
Perfect RSi. and my wife has been bugging me about a dehumidifier for the basement.   2 birds 1 stone.  Thanks again.
