Author Topic: pump question  (Read 5209 times)
mule20
  • OWF Brand: none
  • OWF Model: none
pump question
« on: February 06, 2014, 01:46:10 PM »
i got a new guy question again if i run 200ft from boiler to inside propane furnace do i need another pump for return flow or does someone make one large enough and the ground is pretty flat thanks
Re: pump question
« Reply #1 on: February 06, 2014, 01:52:52 PM »
It also depends on the size of pipe, number of elbows and what kind of heat exchanger(s) you are pumping though.
With that length you will probably be looking at something like a Taco 0011 or 2400-20wb, Grundfos UPS 26-99, B&G NRF36 or PL36, Honeywell PC3F2699IUF00.
There also a lot of Chinese brands that are about the same size that will be cheaper.
mtoll
Re: pump question
« Reply #2 on: February 09, 2014, 07:08:04 AM »
So are you saying you can get by with one pump or a smaller one on the boiler and a small one after the furnace heat exchanger.
Ride HD Road Glide
Vet  USN / USMC
