Author Topic: HELP PLEASE  (Read 18881 times)
jerkash
  • OWF Brand: Legend
HELP PLEASE
« on: February 15, 2014, 07:52:57 AM »
I am thinking about buying a Shaver OWF, making my own lines and burning green wood.
What do you think?   :bag:
HAHA -
ffbare
  • OWF Brand: ridgewood
Re: HELP PLEASE
« Reply #1 on: February 15, 2014, 10:18:29 AM »
I am thinking about buying one too but the thermal wind 2000. I was hoping to get some info on it before I dump 4,797 on it. I was also thinking about the artic fox air stove or a hopsco. Can anyone help me. Thank you
jerkash
  • OWF Brand: Legend
Re: HELP PLEASE
« Reply #2 on: February 15, 2014, 10:30:04 AM »
ffbare - I was only making a joke - Go the this home page and scroll down to Shaver and READ - YOU DO NOT WANT A SHAVER!!!! :bash:
Re: HELP PLEASE
« Reply #3 on: February 15, 2014, 01:40:59 PM »
jerkash - If that's you pictured in your avatar, you can post anything you want.  Roger
Re: HELP PLEASE
« Reply #4 on: February 15, 2014, 03:31:27 PM »
Wow, all of those are sketchy on there Best days...  read on here a lot, read read read
ffbare
Re: HELP PLEASE
« Reply #5 on: February 15, 2014, 04:08:45 PM »
I have reading as much as I can about outdoor units. I Have been burning wood inside for over four years I have a osburn 2400 that I love when I'm home the problem is I have to babysit It every hour to put more wood in.  I was thinking about an outdoor air stove because how my house is laid out and my old completely junk ductwork it just makes more sense to me. I'm not home offen sometimes gone for days at a time so that was one reason I am unsure about a boiler. Any comments would be grateful. Thanks
Re: HELP PLEASE
« Reply #6 on: February 15, 2014, 05:38:09 PM »
FFbare, Many options out their for you. The outdoor air furnace should really be your last choice(especially Shaver's). I am not sure what you mean by 'junky ductwork in the house'? Could you elaborate on that? If you need to leave for days frequently then you can easily use an OWB, you will just have the upfront cost of filling with an antifreeze solution.
ffbare
Re: HELP PLEASE
« Reply #7 on: February 15, 2014, 06:16:13 PM »
Well I have a old farm house from 1852 that has been added to 3 to 4 times over the years. My up stairs 2nd floor has no ducting at all. I did cut in a chase in an interior  wall which kinda works. Needless to say the rest is just as bad plus not much for cold air returns.  I was thinking about running a new duct in the basement and cutting in a few new heat registers  and cold air returns and keeping my existing furnace and a.c. with the old duct work.  I dont wanna push heat with my furnace because the ducting is horrible and the fan on my furnace wouldn't work very well unless I do a complete duct work install for my house which might be a option.
Re: HELP PLEASE
« Reply #8 on: February 15, 2014, 06:27:36 PM »
ffbare, if the system is in that bad of shape, do yourself a favor, do some research,find a contractor you can trust and listen to his suggestions, don't write him a blank check but listen to what he says.
ffbare
Re: HELP PLEASE
« Reply #9 on: February 15, 2014, 06:56:36 PM »
Yeah it wouldn't be the end of the world to redo all of my duct work I'm in the trades I'm and electrician I know a few tinners who I talked to about helping me out. I should just rope my buddy into helping me out.   So the more I read I am understanding it seems every one uses a boiler I am just not sure about letting it get too cold if I don't heat for a few days. I think I would need antifreeze or glycol to keep from freezing.  I guess I don't know if a boiler would keep my house 80 degrees or warmer. My indoor wood stove works great but I have to feed it every hour
Re: HELP PLEASE
« Reply #10 on: February 15, 2014, 07:01:43 PM »
Our house was similar, one small duct in an interior wall that fed two rooms upstairs and the third room had a vent in the floor that came down to the living room. Heat from the living room rose up into the third room.
I blanked off the vent in one of the rooms and ran another vent into the second room up thru a 1st floor closet. Got a vent into the third room by going up the wall of the basement stairwell. Boxed the vents off and drywalled over them. To get heat into a downstairs room that has an inaccessible crawl space I ran another duct along the wall and up tight to the ceiling in the office then boxed and drywalled over that. Had plenty of cold air vents downstairs, but none upstairs. Placed on in the kick plate at the bottom of the stairs since the stair door is mostly shut wan ways.
Re: HELP PLEASE
« Reply #11 on: February 15, 2014, 07:04:02 PM »
One of two options there, either find a good buddy and buy him a six pack for stopping by once a day to fill your new OWB while your gone.
Or fill it clear full, then use backup heat and not the boiler to heat your house while your gone.
ffbare
Re: HELP PLEASE
« Reply #12 on: February 15, 2014, 08:19:07 PM »
I'm going to do some reading on here but is it possible to heat up a house to 80 degrees with a boiler?  If I could find a decent boiler for under 6 grand with all the parts I would totally do a boiler but an air stove would be much cheaper from what I'm reading. I'm just nervous about a boiler because of water freezing up or rusting out my owb or keeping my home warm enough. Are people really getting 10 to 14 hours before filling up their owb and can I get some pros and cons for a nice stove, also is it worth buying the biggest one I can afford? The less I have to fill it with wood the better obviously.
Re: HELP PLEASE
« Reply #13 on: February 15, 2014, 09:44:21 PM »
1: I was picking corn late one night, wife wasn't feeling well and had the chills. Instead of turning the thermostat up, she turned the fan to manual on the thermostat. It was 86 when I came in late that night. Went back outside and stripped the Carharts and most of the rest of my cloths off, spent a few minutes trying to figure out WTF was going on after I walked around and opened most of the downstairs windows. Next morning I made it quite clear she was never to touch the fan switch again and it was ALWAYS to be left on Auto. OWB did that. 80 shouldn't be  problem unless you're still using animal skins for windows and a chunk of canvas tarp for a door.
2: You get what you pay for, old farm house originally had a coal furnace, that was converted to oil, then had a wood furnace in the basement. Father and both his parents said this old house was never as warm as it was before I went with a outside boiler. House stays cleaner and the humidity stays up a lot better no matter how cold it gets.
3: My home built is going on 14 years old, no leaks, water looks clear. It would have to be out for days before freezing was a real possibity. Bypasses could be installed so no water flowed thru a sidearm or plate HX and your duct HX.
4: If filled clear full of oak and red elm I've gone two full days, most efficient though to only fill enough to get a 12 hour burn at a time.
5: Size it according to your heat load, if it's too big you could have the very real possibility of it going out on warmer days as it won't cycle enough. Bigger also costs mucho more $$$.
« Last Edit: February 15, 2014, 09:47:41 PM by mlappin »
ffbare
Re: HELP PLEASE
« Reply #14 on: February 15, 2014, 10:05:11 PM »
Yeah thanks for that mlappin  the more I read the more I may go with a boiler. Now I'm reading on everyone's thoughts about each brand and so on. I need to see what dealers I have near me. I live in Jackson Wisconsin everyone in my little old area burns wood but all indoor wood stoves. I want to be a first of my neighbors to get an outdoor unit. They should be allowed because down the road a mile or so a few of those guys have owbs. I just want to burn wood and come home after 10 to 14 hours and have a warm house. I'm not worried about wood, for the last 4 to 5 years I have had plenty. I'm still burning wood I made like 3 years ago I just wanna be able to make bigger pieces and save time on splitting and  loading every hour. This is going to be expensive I am going to redo my duct work and go with a boiler. At least my a.c. will be better in the summer than.
