Author Topic: power outage  (Read 20322 times)
trz
power outage
« on: February 15, 2014, 10:07:41 AM »
How do.you handle a power outage if you don't have a generator?
Re: power outage
« Reply #1 on: February 15, 2014, 11:12:06 AM »
If you want heat with an outdoor boiler then buy the generator.
PitMan
Re: power outage
« Reply #2 on: February 15, 2014, 11:19:38 AM »
Thats not rly answering the question.. ??? Im sure most ppl dont have a generator and Im sure some have experienced a power outage.
Re: power outage
« Reply #3 on: February 15, 2014, 11:25:16 AM »
  I wasn't being smart, simply stating that without power the circulators that are required to get the hot water to the house will not work and the blower, solenoid and aqua-stats also need power to control the fire. A very small 1000 watt generator will run your entire heating system.
trz
Re: power outage
« Reply #4 on: February 15, 2014, 11:29:45 AM »
Haha, I well aware that you need power. What I was wondering was whether there were any thing specificallyi should do in the event of a power outage if you don't have a generator.
Re: power outage
« Reply #5 on: February 15, 2014, 11:34:23 AM »
Be aware of possible overheat and steam depleting the water level in the boiler, if you have a pressurized unit be sure the relief valves work.
TM88
  • OWF Model: 5000E
Re: power outage
« Reply #6 on: February 15, 2014, 12:58:44 PM »
Trz we lost power last year for 2 days and had to resort back to the fireplace insert in the house for heat for that time. What I did was when my stove was getting ready to boil over due to the circular pump to the house not running I ran a extension cord to my pump and plugged it into a 12 volt 120 converter off my truck to circulate my water until it cooled it off and my coals burned out low enough to not have to worry about it anymore. Also I had just loaded it before we lost power and dug most of the wood out that I could.
TM
ITO
  • OWF Brand: HS1
  • OWF Model: 555
Re: power outage
« Reply #7 on: February 15, 2014, 01:22:34 PM »
 Not sure what boiler you have but my conventional will go into smolder mode with no fan, the embers will stay lit for a few days if using good wood, one thing you dont want to do is open the door and let the fire roar without any pumps, the embers will keep the water hot enough so you shouldn't have to worry about freezing but that is something to watch for if it's subzero, windy and lengthy.
Roger2561
Re: power outage
« Reply #8 on: February 15, 2014, 01:38:24 PM »
Would a Uninterruptible Power Supply (UPS) have enough "juice" to run the circs, solenoids, etc...?  I have a generator but for those who can't afford one, perhaps a UPS may fill the void?  Just a thought.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
MattyNH
  • OWF Model: 7300E ; S-275
Re: power outage
« Reply #9 on: February 15, 2014, 02:46:07 PM »
Well back in the ice storm of '08 I had no power for 32 hrs..Had a live fire in the OWB…No generator either.. Basically what I did is stuffed insulation around pipes and on the pump..Didn't want nothing to freeze..
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
lindnova
  • OWF Brand: Heatmor
  • OWF Model: 200 CSS
Re: power outage
« Reply #10 on: February 15, 2014, 03:01:04 PM »
I would just light the stove in the basement.  I would run the generator enough to circulate and avoid frozen lines if it was for days.  Mine would just sit there and smolder even if a full load; not too worried about overheating.
Stihl ms260, ms362, msS461
Huskee 22 TN Splitter
Kubota BX2200 w/ Loader
Re: power outage
« Reply #11 on: February 15, 2014, 06:03:02 PM »
Lindova, read Roxann's recent posts
netwerx-r-us
  • OWF Brand: Tennessee Outdoor Furnace
  • OWF Model: Hoss 400HE
    • Netwerx-R-Us
Re: power outage
« Reply #12 on: February 15, 2014, 06:17:43 PM »
Here's what I did in a pinch , not saying its the right way but it worked, I gambled when i did it , knowing I could ruin a 100 dollar alternator or loose about 25,000 in inventory , that was the choice at the time , kinda a no brainer, but all went well and no damage to vehicles months later
 http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=4319.msg33658#msg33658
Mark
Netwerx-R-Us
http://netwerx-r-us.com
Kubota 3430 W loader and backhoe
Echo 440
Honda Rancher 400
Kubota ZD326
trz
Re: power outage
« Reply #13 on: February 15, 2014, 06:38:02 PM »
Thanks all. I guess if I ever loose power I'll just keep an I on it and let it smolder!  Mine doesn't typically burn hard without the fan on so I think it. Would just smolder for a long time.
juddspaintballs
Re: power outage
« Reply #14 on: February 15, 2014, 07:00:31 PM »
Seriously, just buy a generator.  They're cheap, very useful, and you'll be able to run your system without any worry or modifications.  Even if you never plan on back feeding your house with it, you can at least run your fridge, a few lights, and other vitally important items in the house anytime you lose power (and your boiler).  You can also haul it out into the middle of a field and have power out there for whatever reason you might need it.  Heck, use it to power something 220v in the garage if you don't have 220v out in the garage already.  As a homeowner, it's almost stupid not to own at least some type of power generating device for when the power goes down.
If all you want to run is a small load like your boiler and circulators, then this cheap generator will work just fine.  There's a coupon on the main page of the site for $99 for this one.
http://www.harborfreight.com/900-peak800-running-watts-2-hp-63cc-gas-generator-60338.html
Otherwise, search craigslist and you can find generators 6000 watts and down reasonably priced (new) at around $100 per 1000 watts.
