Author Topic: Octagon firebox/water cooled door  (Read 17289 times)
menchhofer
  • OWF Brand: o
  • OWF Model: o
« on: February 25, 2014, 05:11:15 PM »
What would be the advantage/disadvantage of the octagon firebox vs. a round one? More surface area? Would it really matter?
Advantage of water insulated/cooled door on firebox?
Re: Octagon firebox/water cooled door
« Reply #1 on: February 25, 2014, 05:37:13 PM »
I don't see any real advantage to a water cooled doors, especially the ones that are exposed to the atmosphere, they'd lose as much heat as they'd pick up it seems to me.
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
« Reply #2 on: February 25, 2014, 06:04:50 PM »
Round fireboxes seem to last the longest.
cantoo
  • OWF Brand: Western Pacific
« Reply #3 on: February 25, 2014, 06:22:08 PM »
Octagon firebox might mean more chance of weld failure due to extra corners? I would think that round would be more resistant to bending than flat steel. I can see that a small welding shop might prefer to build an octagon one because they don't have machinery to make a round one whereas a break would make an octagon one easily.
« Reply #4 on: February 25, 2014, 07:00:25 PM »
Neither impress me
When u see odd stuff like that it's often an attempt to correct an issue
« Reply #5 on: February 25, 2014, 07:12:09 PM »
I don't think round or octagon matters much as long as it ain't square. Square as in 90  degree corners are more prone to crack it seems.
« Reply #6 on: February 25, 2014, 08:55:47 PM »
Cracks are more likely to form at the bends tho, one of the most common places to see a crack inside a stove is just inside the firebox where the door flange extends out.   Where that 90 degree corner is you'll often see a cracked extend out from it, most never reach the water jacket tho
Anytime there is an angle this is more likely to happen
But with that being said, I think the top companies could make anything work.  It's just like the ripple roofs,  can central and Empyre do it, yes of course, could everyone?  Im not sure.  But I'm not saying it's a huge deal but just saying different styles have been problematic for some and not for others
« Reply #7 on: February 26, 2014, 09:40:14 PM »
All the boilers I built were ripple roofs, not one has leaked yet.
It's not so much the design as whether the company is paying for somebody that can just run a bead or are willing to pay someone that can actually weld. Technique plays a big a part as design. I've seen some factory welds from respectable company's that I'd never let leave my shop.
Speed, penetration, heat, undercut, the mix of the gas for MIG and termination all play a part. I've used both hands to adjust wire speed on my big MIG machine as I just needed the littlest tweak, somebody standing a arms length away wouldn't be able to tell if I had moved it or not, but it does matter.
« Last Edit: February 26, 2014, 09:45:40 PM by mlappin »
« Reply #8 on: February 27, 2014, 06:50:52 AM »
Yea..  I know a good welder could make anything work
I know that we often see stoves have similar issues tho and since once company goes into left field to fix it they have to have an answer for the question when someone asks.  Like water cooled doors for example,  needed? No.  Was it a likely attempt to correct door warping and add efficiency,  yes.  Has it proven to be better than a well built insulated door,  no, but they gotta tell ya something haha
boyland
« Reply #9 on: February 28, 2014, 02:42:04 PM »
I can answer a very specific question about doors since I am the designed of Wood Boiler LLC.  When I built the first boiler I had a very specific safety requirement.  I did not want my small girls to touch the door and get third degree burns when I was not home and they were playing in the backyard.  All other benefits are just a bonus.  Warpage is funny statement because warp age occurs because of welding a water cooled door the hotter and longer the weld it is natural byproduct.  Or you can use really thin metal and jig it that is another solution used by some companies.
We may be small be we have an in-depth knowledge of our products and quite frankly we have some of the best on the market.
As far as bending metal I have never witnessed a single crack in plate from a bend you have to keep in mind all manufacturers either roll or bend to reduce the number of weld points just part of the process.  This in my opinion is a lack of metallurgy knowledge to say it causes cracks, this simply not the case if you understand the process.
« Last Edit: March 01, 2014, 09:18:26 PM by boyland »
menchhofer
  • OWF Brand: o
  • OWF Model: o
« Reply #10 on: February 28, 2014, 03:12:10 PM »
I can answer a very specific question about doors since I am the designed of Wood Boiler LLC.  When I built the first boiler I had a very specific safety requirement.  I did not want my small girls to touch the door and get third degree burns when I was not home and they were playing in the backyard.  All other benefits are just a bonus.  Warp age is funny statement because warp age occurs because of welding a water cooled door the hotter and longer the weld it is natural by product.  Or you can use really thin metal and jig it that is another solution but the other companies.
As far as bending metal I have never witness a single crack in plate from a bend you have to keep in mind all manufacturers either roll or bend to reduce the number of weld points just part of the process.  This in my opinion is a lack of metallurgy knowledge to say it causes cracks, this simply not the case if you understand the process.
Still do not quite understand the water cooled door. Kids can be taught not to touch no big issue there.  Why the octagon firebox?
 I live about 20 miles from Lebannon and seriously considering your boiler. Just have not had time to visit your place of business.
« Reply #11 on: February 28, 2014, 03:22:29 PM »
Thanks for weighing in, yes fewer welds is a good thing.  Sharp corners is why I'm referring to as far as points where cracks can form, not bent corners.
Does your door temp Match the water temp of stove?  If so are u concerned with that heat being lost
In regards to warpage,  many doors work because there not properly insulated, I wasn't referring to the warping that comes from the welding process.   I have seen many doors warp very badly due to heat from issues and low quality insulation
boyland
« Reply #12 on: March 01, 2014, 09:03:57 PM »
I would think any steel door would risk warping without water in it because of heat unless a couple of factors one doors with inducers tend to be cooler because the air is injected front to back but they still get pretty darn hot, I have run ours without water more as a curious factor.  Never warped but certainly would not want to touch.  The heat loss to be far outweighs the risk.
Safety, I felt I could not teach every kid that might visit my daughter or close by kids.  Just always and still do feel that is the reason, I built the water cooled door.  The return water is sent through the door so it tends to be cooler than the rest of the boiler in general.
Octagon this applies to conventional style boilers
1.  Round boilers provide about the best overall ability to feed the wood to the central fire however the center point at the top is the largest area of heat transfer in this design all you have to do is look at the thermal images to see this looks like about a 3-4 inch strip.
2. Square top boilers provide the largest heat transfer actually these provide the greatest surface area to transfer heat however keeping them burning is harder they tend to burn the center out leaving the side wood unburnt.  Again a pretty nice and even transfer across the surface.
3. Octagon provides a mix of the 2 giving us larger heat transfer surface area whilst giving it a self feeding effect.  This is why.
And if you are curious yes built and tested about every design type you can think of the octagon worked about the best in my opinion from durability to usability.
The downdraft units are a complete different ballgame.
boyland
« Reply #13 on: March 01, 2014, 09:12:54 PM »
Scott on the door warp, I am not sure what your mean by insulation, I think you are referring to the refractory material?  Which is a non issue with our boilers.
« Reply #14 on: March 01, 2014, 09:36:01 PM »
No, I'm talking about actual insulation inside a pyramid shaped door
It's what most companies use, they stuff the pyramid cavity with stuff like vermiculite and other high heat insulations.  These keep the door barely warm to the touch, for example the door on my heatmaster in 20 degree weather is probably 55 or 60 degrees.  There are a lot of companies tho that use the same style door.
