Author Topic: How electricity works  (Read 3480 times)
« on: March 12, 2014, 09:13:57 PM »
ELECTRICAL THEORY BY JOSEPH LUCAS
Positive ground depends on proper circuit functioning, which is the transmission of negative ions by retention of the visible spectral manifestation known as “smoke”. Smoke is the thing that makes electrical circuits work. We know this to be true because every time one lets the smoke out of an electrical circuit, it stops working. This can be verified repeatedly through empirical testing.
For example, if one places a copper bar across the terminals of a battery, prodigious quantities of smoke are liberated and the battery shortly ceases to function. In addition, if one observes smoke escaping from an electrical component such as a Lucas voltage regulator, it will also be observed that the component no longer functions. The logic is elementary and inescapable!
The function of the wiring harness is to conduct the smoke from one device to another. When the wiring springs a leak and lets all the smoke out of the system, nothing works afterward.
Starter motors were considered unsuitable for British motorcycles for some time largely because they consumed large quantities of smoke, requiring very unsightly large wires.
It has been reported that Lucas electrical components are possibly more prone to electrical leakage than their Bosch, Japanese or American counterparts. Experts point out that this is because Lucas is British, and all things British leak. British engines leak oil, British shock absorbers, hydraulic forks and disk brake systems leak fluid, British tires leak air and British Intelligence leaks national defense secrets. Therefore, it follows that British electrical systems must leak smoke. Once again, the logic is clear and inescapable.
In conclusion, the basic concept of transmission of electrical energy in the form of smoke provides a logical explanation of the mysteries of electrical components especially British units manufactured by Joseph Lucas, Ltd.
And remember: “A gentleman does not motor about after dark.”
Joseph Lucas “The Prince of Darkness”
1842-1903
Re: How electricity works
« Reply #1 on: March 13, 2014, 03:56:17 AM »
RSI - Now you've done it, the secret is out.   :)   Roger
« Reply #2 on: March 13, 2014, 04:15:46 AM »
When I opened this up this morning I thought it was going to be one of those hum drum things that I never finish reading, Thanks RSI, you started my day with a smile on my face!!!!
ITO
  • OWF Brand: HS1
  • OWF Model: 555
« Reply #3 on: March 13, 2014, 07:10:11 AM »
 Perfectly logical! Thanks RSI, have to admit that me smile also.
bajonesy77
  • OWF Brand: Prosteel
  • OWF Model: 200
« Reply #4 on: March 15, 2014, 12:46:24 PM »
I took some electronic courses in college and was like wtf at first but keep reading and was like oh ...........it finally hit me  :bag: ;D
Brave 22 ton splitter
Stihl 440 magnum 20" bar
Stihl 390 20" bar
