Author Topic: E-Classic 2300 (2009) - Firebox door issue  (Read 9616 times)
buckgrunt
  • OWF Model: E-Classic 2300
« on: March 16, 2014, 04:16:00 PM »
Hello,
I have an E-Classic 2300 manufactured in 2009 and I have encountered a little problem.  I recently replaced my door gasket for the first time and noticed what appeared to be some crumbling of the door insulating material that is bolted under the metal panel that faces the fire.  This appears to be causing some smoke/air to escape the firebox and leak through the door when the fan is on.  I believe that CB provides a replacement kit for the fire box door parts.  Does anyone out there have a similar experience ?  Cost ?
CentralBoiler3200User
  • OWF Brand: Central Boiler 3200
  • OWF Model: 3200
Re: E-Classic 2300 (2009) - Firebox door issue
« Reply #1 on: March 24, 2014, 09:30:24 PM »
No Idea...
Though I have the 3200, going on 3 years and understand what you are referring to.
Maybe you can find it thru ebay...
I replaced our gasket last year.... son shut the door on a small branch and melted the gasket where the air escaped.
Do you use lime daily or their CB product?
Big Wood
« Reply #2 on: April 12, 2014, 06:24:43 PM »
Contact your local dealer if you purchased this boiler new it is under warranty there is a replacement door assembly available from central boiler
dwneast77
    • HeatherWood Gardens
« Reply #3 on: April 17, 2014, 11:47:43 AM »
Yeah, I have the 2008 E2300.  Just replaced my door guts a month or so ago.  The kit is $245 to buy.  But my dealer sent me a warranty form to fill out and send back.  All I was liable for was $45.09 for shipping.  It is messy to clean out the old but was a pretty easy job for me.  I had no troubles and even did it while there was still a bed of coals in the stove.  Kit contains virtually all new parts except the outer door shell.
Jeff
Eastern Maine (near Calais)
Central Boiler E-2300
Wood Doctor HE10000
Stihl 290 Farmboss
Craftsman 27 ton Splitter
JD 870 Tractor
Big Wood
« Reply #4 on: April 17, 2014, 06:51:10 PM »
Have you changed out your  reaction chamber the air box burns out on the under side they have a replacement for that too
sam-tip
  • OWF Model: E3200 (2011)
  • Overkill is under rated
« Reply #5 on: June 13, 2014, 04:48:42 AM »
I just changed my door seal on my E3200.  I think it is the same for the E2400.  About $50 on ebay.  Burns way better now.  Seal was 3 old.  Should have done it after 2 years.  Only took 5 min to change the seal.  The seal came out very easy and little cleaning for new one.  I expected the worst but was glad to see the metal in very good shape.
E3200
All ported 355T, 346xp, 562xp, 395xp, 3120xp
Silvey pro sharp, 5 year wood supply
Hobby hording oak firewood.
Overkill is under rated!
pintopaul
  • OWF Brand: wood master
  • OWF Model: model 434
« Reply #6 on: October 29, 2014, 06:44:07 PM »
tried to order a door last fall was told not available, this year i tried a differant dealer in a differant state and low and behold replacement parts are available have a fax coming tomorrow with prices and part numbers needed to fix this.
Big Wood
« Reply #7 on: October 29, 2014, 07:06:30 PM »
If you haven't replaced you fan check the part number they also made a change and up sized the fan
