Author Topic: CB E1400 LO but water gauge says full?  (Read 6169 times)
johnybcold
  • OWF Model: Classic E1400
« on: March 22, 2014, 11:22:25 AM »
Anyone ever have this issue? The boiler will not fire up the display flashes LO which means low water but the gauge says it is full I added some water to see it that would fix it no luck, just filled it until it over flowed still says LO.  :bash:
« Last Edit: March 22, 2014, 12:08:16 PM by johnybcold »
old truck
old craftsman chain saw
Polaris Sportsman 500HO
johnybcold
Re: CB E1400 LO but water gauge says full?
« Reply #1 on: March 22, 2014, 12:09:20 PM »
update there is a sensor behind the display panel mine is dead, I would think it would be covered under warranty guess I will find out Monday
old truck
martyinmi
  • OWF Model: Optimizer 250
« Reply #2 on: March 22, 2014, 01:59:12 PM »
Over at the Forestry Forum the issue that you are having was discussed a year or two ago.
I think to get by they simply ran a jumper between the two wires that attach to the low H2O sending unit(switch is closed when water is present).
I'll bet your dealer knows how to bypass it until he can get you a new one.
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
