Author Topic: Distance of stove from your house  (Read 17999 times)
eddie123
  • OWF Brand: natures comfort
  • OWF Model: 250
« on: March 31, 2014, 05:29:33 PM »
Hello everyone, Posting some questions for my Hubby. We just recently ordered a Natures Comfort 250, waiting for it to be delivered. Hubby is trying to decide where to place it and how far from the house. He also is undecided on a full slap or just concrete at the legs. Does anyone have an opinion to share? Pictures of how you have done your stove would also be nice. Thanks
ITO
  • OWF Brand: HS1
  • OWF Model: 555
Re: Distance of stove from your house
« Reply #1 on: March 31, 2014, 06:09:42 PM »
 Welcome, a few things come to mind, you can find a preformed slab, that has worked for me, if your going to pour a slab it's nice to have a poured piece in front of the door so you can clear snow easily. Some insurance companies want a distance from the house, mine says 25' min. The further you put it the more $ you will have in underground pipe and it can get spendy. Good luck with the install.
« Reply #2 on: March 31, 2014, 07:43:26 PM »
READ READ READ, there is so much info on this site it will make your head spin,  WELCOME ABOARD!!!!!
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
« Reply #3 on: March 31, 2014, 07:59:19 PM »
I would give him a full slap. Hahaha anyway pour the concrete you won't regret it especially spring thaw.
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #4 on: March 31, 2014, 08:11:32 PM »
If you can afford it, pour the concrete! And leave lots of room in front of the stove. More than you think you would need!
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
BoilerHouse
  • OWF Brand: Home Built
« Reply #5 on: April 01, 2014, 04:53:45 AM »
My boiler is 165 feet from the house and 90 feet from the garage in a corner of the property with lots of room for receiving a load of logs and cutting, splitting and piling that load.  However, you do want to keep in mind that you will be going out to fill your boiler in the dark when it could be raining or snowing.  Also, consider prevailing winds so any incidental smoke is carried away from you and your neighbors.
Muskoka, Ont
oldchenowth
« Reply #6 on: April 01, 2014, 04:56:10 AM »
I poured two short slabs under the persches and a 4' slab in front of the door.   Pour the whole slab under the stove and 6' to 8' in front of the door.  You will not regret the extra space.
Distance - insurance company and local ordinance is king.  Other than that, close to your wood pile.
MO_Hunter
  • OWF Brand: Heatmaster SS
  • OWF Model: CS-4000
« Reply #7 on: April 01, 2014, 12:30:57 PM »
Mine is installed 20' from my house on a full slab.  Pour the slab can not count how many time hot coal have drop on the ground when opening the door.  Easier to stomp out or scoop up off concrete.  Mine sits under our yard light so nighttime fills are not a blind event
Have a friend that install his over 100 ft away but he heats his barn also so he split the distance. It still make a walk to load in the dark.
« Reply #8 on: April 01, 2014, 07:01:11 PM »
Im 90ft from my house then another 30ft in my basement to my oil boiler.. Yeah def pour the extra slab where you will be loading the stove..Wish I did it...
fireboss
« Reply #9 on: April 01, 2014, 07:47:46 PM »
Iam  14' away from the house, the town said 12', its nice when its bad weather out and lots of snow on the ground
« Reply #10 on: April 02, 2014, 08:05:23 AM »
I am about 20' from garage (50' OWB to Mechanical room) & maybe 50' from house (75' OWB to Mechanical room), about as evenly split as I coudl go with out major headache (water/sewer/electrical)
No agree, that shoudl check with insurance, might get a break if over a set distance from structure.  Also must meet local code ordinace.
Lamont
« Reply #11 on: April 16, 2014, 10:36:01 AM »
I'm building this summer and putting in OWB, so I just called my insurance guy (and local fire chief) that carries a number of different companies, along with his dad carrying another company.  He said they range from 30-50' with their policies so he told me to stay at least 50' away from any structure so I can shop around different companies when I want to.
ffbare
  • OWF Brand: ridgewood
« Reply #12 on: April 16, 2014, 03:53:52 PM »
If your about 20 feet from your house how tall would your chimney need to be?
« Reply #13 on: April 16, 2014, 04:12:48 PM »
With the unit that close, if it smokes you will want extend over the peak and that will suck the heat out of your unit unless you install a barometric damper on the stack.
ffbare
« Reply #14 on: April 16, 2014, 04:48:19 PM »
Are chimney fires an issue or sparks shooting out of the top?
