Author Topic: Best Technique for Removing Logstor Outer Casing & PUF Insulation  (Read 7643 times)
I am hoping those who have more experience than I with Logstor could answer a simple question...
What is the "proper" or best way to remove the outer black casing and insulation from the last foot of Logstor Dual PEX-Flex piping (without damaging the PEX tubing)?
I am speaking to the ends of the installed pipe where the Pex will attach to my water jacket and the Pex in the Logstor as the pipe enters my home.
Thanks!  -Slopster
« Last Edit: April 04, 2014, 10:45:30 AM by Sloppy_Snood »
Re: Best Technique for Removing Logstor Outer Casing & PUF Insulation
« Reply #1 on: April 04, 2014, 11:03:26 AM »
  A utility knife and good blade, 1 vertical cut down the length and then1 cut around the pipe, the black plastic can then be removed exposing the foam. Next take a stout screwdriver and poke it through the foam, between the pex lines, twist the scewdriver sideways splitting the foam and then strip away the foam with a sharp knife, be careful to not damage the pex with this part. lastly, before inserting the compression fittings into the pex take the sharp edge off the pex with a sharp knife or it can cut the O rings.
« Reply #2 on: April 04, 2014, 12:18:49 PM »
Thank you as always slimjim!  :thumbup: 8)
« Reply #3 on: April 04, 2014, 12:28:49 PM »
How much "naked PEX" should I leave coming out of the Logstor insulation.  The Logstor endcap needs a couple inches but beyond that, how much more for fitting attachment and anything else that is needed?   :-\
« Reply #4 on: April 04, 2014, 02:52:43 PM »
  6 inches will give you enough room for the compression fittings
« Reply #5 on: April 04, 2014, 02:58:25 PM »
Thank you again Sir.  :thumbup:
« Reply #6 on: April 04, 2014, 03:11:08 PM »
If you were standing downwind of me right now you would not call me sir, WOW it's been hot today, time for a shower and cold Merrimack river water, hops and barley mixture.
