Author Topic: What temp do you run your boiler at?  (Read 21031 times)
RUGERGUNZ
  • Central Boiler 6048
« on: June 01, 2008, 03:44:20 PM »
My Central Boiler came from the factory set at 185.  I am going to run it all summer and have turned it down to 175 today.  Is there any disadvantage to running lower temps?  Will it cause significantly more creosote?
Thanks
gandgracing
Re: What temp do you run your boiler at?
« Reply #1 on: June 05, 2008, 02:08:19 AM »
I own a shaver boiler and run the water temp at 150
RX7145
« Reply #2 on: June 16, 2008, 01:57:27 PM »
I run 165 on off at 175. Any hotter and I use more wood.
Stihl 0011AV
Stihl 009
Stihl MS170
Stihl MS290 20' Bar
CB 4436
Husky455
« Reply #3 on: June 17, 2008, 06:40:32 PM »
When it is cold, it is on at 1654 off at 180.  Bump it up a bit one the EXTREME days.  Drop it down to 140 or so when it is mild such as fall and spring.  Don't run it iin the summer.
pdboilermaker
  • www.princesspetitepoodles.com
    • Princess Petite Poodles
« Reply #4 on: January 14, 2009, 11:28:32 AM »
20-40 outside temp with 10mph wind or less - on 140 off 150
20-40 outside temp with 11mph + winds - on 150 off 160
0-20 outside temp with 10mph wind or less - on 150 off 160
0-20 outside temp with 11mph + winds - on 170 off 180
Woodmaster 4440, Sthil ms310, Jeep Wrangler to pull home the wood, Noritz tankless water heater, smart car
« Reply #5 on: January 14, 2009, 06:15:35 PM »
i dont know if it is true or not bu t iread on a forum one time on boilers that if your water is under 180 that the corrosion facto increases..that said i run my home made OWB at 145 to 160 anyway
Scratch
  • OWF Model: CB6048
    • Edge Metalworks
« Reply #6 on: January 14, 2009, 06:30:10 PM »
My CB is factory set at 185 and since I'm still a newbie... I think I'll leave it for now... ;D
Hudson, WI
ckbetz
« Reply #7 on: January 14, 2009, 09:23:10 PM »
I talked to a rep at Central Boiler and he told me to always keep it at 165 or above.  I have the large cast iron radiators so I can heat my house for most of the winter at 165-170.  When it gets really cold I'll bump it up to 185 but this year it's only been there for a couple of days.  I do know that the hotter the inside of your furnace the better draft you'll get, so you'll get a more efficient burn at the higher temps.
Pomeroy, Ohio
