Author Topic: Empyre 200pro Install  (Read 18664 times)
Hammersquash
  • OWF Brand: Empyre
  • OWF Model: 200 ProHS
« on: April 19, 2014, 06:27:32 AM »
Hello All,
  At the request of Jwood I am going to post my progress in this message thread and attach photos for all to critique.  Normally when I take on a project that is not my area of expertise I like to do it quietly, under darkness at the witching hour, without mention to my family and friends so I can plow my way through mistakes and no one is the wiser.  This time I am offering up my humble project and its photos for this community to critique.  I am interested in doing the best install I can and will appreciate any information anyone has to offer.
   Before anyone pipes up I know the Empyre 200pro may have been a mistake.   There is very little info available on it and I was not privy to some of the manufacturing defects and negative service points they may have.  My parents came home with a Beta VCR in the early eighties, we all know how things work.  I chose the Empyre 200 for two reasons;
  A: Cost.  I purchased it from a dealer at under 60 percent of retail value
  B: Two Zones and BTU output.    I have a 2 story farmhouse with great room addition.  Not including the basement it is 2000 square feet and well insulated.  I had holes drilled in walls this winter and insulation injected between studs.  I also had roof re-insulated and 2" of foam sprayed on my brick foundation  in the basement.  My shop is 2100sq feet with 13' ceilings and is well insulated.  I know I am on the upper edge of the BTU output for the whole system but I do not plan on heating the shop throughout the week and a system that is running hot is cleaner and more efficient.
   So here is my plan: (note to slim, no point in emailing you now on my intentions for plumbing schematic, here it is!)
                                      *----------------*  Pex grid in boiler slap and walkway
                                      I
                   Zone 2 ----  *----------------* 35' X 60' Shop.  Water to air heat exchanger
                                      I
     Boiler                        I
                   Zone 1        *----------------* Great room water to air heat exchanger/radiator/baseboard radiator
                                      I
                                      * --------------- Hot Water Heater
                                      I
                                      *---------------- Furnace plenum water to air
                                      I
                                      *---------------- Kitchen Slate Floor radiate joist heat.  (I can make breakfast with ice skates on it seems)
    So as you can see its a medium project.  I can supplement heating requirements in the shop with the wood furnace I installed two years ago.  Should the radiant pad put too much load on the system I can shut it down.  It's easier to put pex in concrete BEFORE you pour it.
    The exchanger in the great room may seem odd but the guy who did the addition did not provide a link to the HVAC system and the addition is built on a slab completely concreted and insulated in.
   I have struggled heating my home for a few years now.  Originally I had a pellet stove in the great room and although it was pour/dial auger speed/walk away for a continuous BTU output I never fully trusted the thing after I came home one day to a house full of smoke and a few burn marks on our hardwood floors when the doors popped open after a backdraft.  I thought it a better idea to install a propane stove in the corner with a handheld remote.  Unfortunately it was better on paper.  The propane stove fights an air mass with the oil furnace and it is impossible to balance out.
  I also have a wood stove in the basement.  It is certified and works great in reducing fuel consumption but getting wood into the basement when there isn't a cellar door is a pain in my ass.  The bugs, soot, odd down draft and my wife constantly nagging me that the house is on fire at 2am every night is not worth the effort.  I would rather stuff a few hundred dollar bills on the 1st of every month under her pillow to shut up.
  So here are three pics for you to view.  The first is basically a shot behind my shop where prying eyes can't see my boiler.  I decided to put it here because of a few reasons.  It is 165 feet from the edge of the house and with the technology of insulated pex I don't think there will be much heat loss.  I do not have any neighbors.  I am the only home on this side of the concession road (thus the lack of natural gas, high speed internet and cable TV) but my family doesn't want to be smoked out when the fire gets fat on those mild days.
  The second photo (while sitting on my tractor) is the area cleaned up and excavation lines drawn out.  The third photo is the 8" of topsoil removed.  Luckily for me after 8" it is mostly clay.
https://www.flickr.com/photos/123605823@N05/13911506286/
https://www.flickr.com/photos/123605823@N05/13934664793/
https://www.flickr.com/photos/123605823@N05/13935051854/
  So I am off to pick up a few yards of gravel today and some other odds and sods for around the house.  I plan to complete the forms this weekend and hopefully pour next weekend.  Like I said, I am totally open to criticism be it positive or negative.
Hope everyone has a wonderful easter and you find all those eggs under your woodpiles next winter!
Stihl 660 Magnum
Kubota BX25
New Holland L213
Fiskars X27
2012 F250 King Ranch 6.7 TD
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
Re: Empyre 200pro Install
« Reply #1 on: April 19, 2014, 07:44:26 AM »
Nice job laying out and planning
Pre planning prevents poor projects
Michigan Thumber
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
« Reply #2 on: April 19, 2014, 07:47:05 AM »
Sounds mostly like a good plan 1 thing I would do different is keep the garage and the slab on their own loop totally separate of the house and as far as the great room where is your furnace located?
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Jwood
« Reply #3 on: April 19, 2014, 07:49:05 AM »
Oh and thanks for allowing us to follow you on your build and put our 2 cents in :thumbup:
Stihl MS 270c
Stihl MS 461
« Reply #4 on: April 19, 2014, 08:10:35 AM »
When I can get the marbles to stop rolling around in my head this morning I will comment, late night last night.
Jwood
« Reply #5 on: April 19, 2014, 08:49:29 AM »
Been there slim I shut it down early last night so I'm feeling pretty good today.
Stihl MS 270c
Stihl MS 461
Hammersquash
  • OWF Brand: Empyre
« Reply #6 on: April 19, 2014, 06:28:23 PM »
  The slab and shop are on loop B exiting the boiler.  I managed to finishing forming today and here are some pics.
First Pic is of my shop and home taken from the edge of my fields.  This give a good perspective of the family room addition and the shop.   The boiler path starts between the shop and the garden shed.
https://www.flickr.com/photos/123605823@N05/13938532534/
Second pic is from back of shop post tamping and forming.  Sorry for the straight edges.. I couldnt be bothered to curve them!
https://www.flickr.com/photos/123605823@N05/13940292595/
 Third pic is walkway
https://www.flickr.com/photos/123605823@N05/13940287655/
  I am picking up mesh and pex this week.  Any suggestions will be slowly digested.
W
« Last Edit: April 19, 2014, 06:37:40 PM by Hammersquash »
Stihl 660 Magnum
Kubota BX25
New Holland L213
Fiskars X27
NaturallyAspirated
  • OWF Model: M250
  • Golfing, snowmobiling fool!
    • http://www.nealmastel.com
« Reply #7 on: April 19, 2014, 07:12:02 PM »
Sweet getup!  I like the shop!   :thumbup:
Neal
Hammersquash
  • OWF Brand: Empyre
« Reply #8 on: April 19, 2014, 07:22:22 PM »
Lighting.  Nothing worse than stumbling through the dark looking for wood ripe for the pickings.  I installed a 400W High pressure sodium light on a photocell and timer.
https://www.flickr.com/photos/123605823@N05/13919477096/
https://www.flickr.com/photos/123605823@N05/13919478286/
Stihl 660 Magnum
Kubota BX25
New Holland L213
Fiskars X27
Jwood
« Reply #9 on: April 19, 2014, 08:22:13 PM »
Sorry Hammer I read your original post to quick now I see that it said just the shop and slab and walkway on one loop so excellent job so far looks very nice!
Stihl MS 270c
Stihl MS 461
Sprinter
  • In the long run
« Reply #10 on: April 19, 2014, 09:24:36 PM »
Are you using foam board ?
Michigan Thumber
Hammersquash
  • OWF Brand: Empyre
« Reply #11 on: April 20, 2014, 05:55:11 AM »
  Yes I was planning on insulating the pex from the gravel.  I have not picked up the foam board yet.  One of my clients is a home builder and I am calling him on Monday to see if his guys can drop off some trimmings.  What thickness should I ask for or is it a universal standard?
   I was going to put down the foam, mesh and pull tie pex to the mesh.  I didn't thing there was any need to heat the bottom of the boiler so I will run my inlet/outlet straight out of the access hole for the boiler.  Thoughts?
Stihl 660 Magnum
Kubota BX25
New Holland L213
Fiskars X27
NaturallyAspirated
  • OWF Model: M250
« Reply #12 on: April 20, 2014, 07:09:34 AM »
Usually good 2" has an R10 value.  That's what I would go with.   :thumbup:
Neal
Sprinter
  • In the long run
« Reply #13 on: April 20, 2014, 12:58:27 PM »
Yes the 2" foam board even for the small walk way will make for killer response time. Don't forget the vertical edges , these are just as important.  Another VERY important detail is to put the pex on chairs so it is within the top 2" of Crete. This will aloof for lower temps and fewer btu to heat the same space. Plus much much less lag time to change temp.
It's the little details that do make the difference.
« Last Edit: April 20, 2014, 01:15:41 PM by Sprinter »
Michigan Thumber
NaturallyAspirated
  • OWF Model: M250
« Reply #14 on: April 20, 2014, 01:23:25 PM »
What are some good options for 1/2 and 3/4" chairs?
Neal
