Author Topic: Unhappy Campers  (Read 21174 times)
coolidge
Unhappy Campers
« on: April 24, 2014, 01:02:09 PM »
Cant win this year i guess, wife told me to shutdown the boiler because it was making the house to hot when it hit 60 outside. Then wants to know why the water isnt as hot as it was all winter.( no boiler have too turn propane on) Then this morning wakes me up and tells me i need to start the boiler, its cold. Go look at the water temp 90 degrees after three days of no fire :bash: Cardboard fire it is, now running wide open. You would think after only three days of no burning you wouldnt miss that gasification flame, shure was nice to watch it roar. :thumbup:
Western Maine
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: Unhappy Campers
« Reply #1 on: April 24, 2014, 01:05:51 PM »
Sounds like my wife, her mind is changing always and when she gets an idea, well there is no talking her out of it!
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
LittleJohn
  • OWF Model: E-Classic 2400
  • Lonsdale, MN
Re: Unhappy Campers
« Reply #2 on: April 24, 2014, 01:41:35 PM »
JUST A SUGGESTION, teach her how to feed the beast (OWB), then she can make it as hot or comfortable as she wants.
...or you just might find out how comfortable the couch is, for even suggesting!
coolidge
Re: Unhappy Campers
« Reply #3 on: April 24, 2014, 02:06:57 PM »
 :o I like that LittleJohn, but she seems too think I waste my time processing wood, I would love to burn oil for a winter like we just had and see the look on her face then >:D
Western Maine
Re: Unhappy Campers
« Reply #4 on: April 24, 2014, 04:02:02 PM »
Mine does the same, surprising how much heat can radiate off the lines and what not in the basement. This time of year if she gets too warm we open a few windows.
Big Wood
Re: Unhappy Campers
« Reply #5 on: April 24, 2014, 06:27:51 PM »
It is still cold enough here in Maine that I have not done this yet but I put my circulator on a light timer and set it to come on 1 hr before I go to work and shut off 3 hrs later and then to come back on 1 hr before I get home and back off 6 hrs later that way the boiler stays hot and you get hot water and heat add wood when needed
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
Re: Unhappy Campers
« Reply #6 on: April 25, 2014, 06:32:00 AM »
Maybe finding a way to wire it so the circ doesn't run all the time, just on a call for heat would help not overheat things. Even a variable speed circ would help some.
Michigan Thumber
Re: Unhappy Campers
« Reply #7 on: April 25, 2014, 08:10:50 AM »
We really don't worry about it that much, if it's getting warm enough outside thats it's getting too warm inside, time to start opening windows and getting some fresh air in after along winter.
coolidge
Re: Unhappy Campers
« Reply #8 on: April 25, 2014, 06:02:48 PM »
 That's what I told her ,to leave the thermostat alone and open windows
Western Maine
victor6deep
  • OWF Brand: Burnrite
  • OWF Model: 228
Re: Unhappy Campers
« Reply #9 on: April 25, 2014, 08:42:16 PM »
What I did was insulated my ped lines in the basement and cut a wall switch in our master bathroom that controls the boiler circ pump. This way the house don't get hot on mild days and when she wants a hot shower she just flips the switch on and when she's done with the shower she turns it off. Works pretty slick
Jack72
  • OWF Model: E-1450 (11)
Re: Unhappy Campers
« Reply #10 on: April 25, 2014, 08:51:59 PM »
That's a good idea victor.     You have a plate exchanger I take it  not a side arm
Chevy 2500 HD 13 Duramax
Stihl 046 036 009
Northern Tool 25 ton Splitter
Re: Unhappy Campers
« Reply #11 on: April 26, 2014, 03:48:44 AM »
VICTOR, YOU ARE A GENIUS!!!  Keep it up and we are going to start truly liking you! HUGS!
Sprinter
  • In the long run
Re: Unhappy Campers
« Reply #12 on: April 26, 2014, 02:25:42 PM »
If you see the tankless water heaters, they have this too. As an option, in Europe its standard. You have a full control panel at your shower. So you only make hot water when you need it.
Just because wood is an easy resource doesn't mean its good practice to waste.
Michigan Thumber
Re: Unhappy Campers
« Reply #13 on: April 26, 2014, 04:44:13 PM »
NO tankless coils on oil or gas boilers in Europe, nice post sprinter
victor6deep
  • OWF Model: 228
Re: Unhappy Campers
« Reply #14 on: April 26, 2014, 10:00:48 PM »
Yes a 20 plate. The setup works great. If we get a low of 40 night I flip the switch on and go to bed.
