Pages: 1 [2]
Author Topic: Wood storage question  (Read 15266 times)
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: Wood storage question
« Reply #15 on: May 28, 2014, 12:29:33 PM »
I have gravel down under my wood pile.  After I clear out a stack, I take a leaf rake and clean up all the debris.   I will be adding a pre-fab carport in the next couple years.  The gravel is easy to walk on and it drains away really well.  It is fairly cheap here in Indiana, about $19 per ton.  I put 10 tons down about 2" thick and have enough area to store 15 cords 4' high.  I considered pallets, but am glad I don't have them.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
ijon
  • OWF Brand: Portage and main
  • OWF Model: 28-40
« Reply #16 on: May 29, 2014, 03:41:02 AM »
Pea gravel would be good for drainage, but might be hard to move around in.
installed in 2014
« Reply #17 on: June 01, 2014, 08:50:49 PM »
Nice think about recycled asphalt, if you can get it repacked tight enough it doesn't let moisture back up thru it.
racnruss
« Reply #18 on: June 01, 2014, 09:24:00 PM »
Concord,
I have a prefab carport too.  I love it, probably best seven hundred bucks I ever spent.  They just showed up and 30 minutes later I have dry wood storage.
I have gravel under my carport/wood storage. Works nice because no tripping or problems rolling the wheelbarrow.  Stays dry under carport and just use a leaf rake in spring to sift bark out and gravel settles.  Outside of carport I have wood too and it is on pallets for air/drainage ect.  but that wood goes under carport for the year of use.
I have a video of my carport and boiler in the Nature's Comfort section under gt-220.
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
« Reply #19 on: June 05, 2014, 06:02:30 AM »
Bump
Michigan Thumber
Pages: 1 [2]
