Author Topic: new install  (Read 9220 times)
higgins11
new install
« on: June 23, 2014, 07:35:29 AM »
Ok here is my situation. I'm looking to install a new outdoor wood boiler for our dairy...........going to run in conjunction with solar hot water panels on the roof
One company who is quoting the install says I need 3 pumps the other company quoting says I can get by with one pump
Here is what I'll be running
Solar panels
hanging heater
pasturizer
hot water heater
how many pumps is enough?
LittleJohn
  • OWF Model: E-Classic 2400
  • Lonsdale, MN
Re: new install
« Reply #1 on: June 23, 2014, 07:50:33 AM »
Short answer is "YES", you can run on one pump, but it might have to be one BIG OL' PUMP.
It also depends on how you plan to control/manage the system.  I know not easy questions to answer, I woudl start with a rough sketch of how you think you want to run everything, then post image and wait for advice/opinions to roll in.
higgins11
Re: new install
« Reply #2 on: June 23, 2014, 08:32:57 AM »
32gpm?
« Last Edit: June 23, 2014, 08:34:39 AM by higgins11 »
Sprinter
  • OWF Brand: Indoor Boiler
  • OWF Model: Menominee
  • In the long run
Re: new install
« Reply #3 on: June 24, 2014, 08:33:15 AM »
One pump is NO good. Unless it's just one small zone. 5 small pumps can move more GPM and use less electricity than one big pump. Zoning give more control and comfort. But your system layout and loads will determine most of what you will use.
How many exchangers are there? Distance from stove to exchanger(s)
Michigan Thumber
LittleJohn
  • Lonsdale, MN
Re: new install
« Reply #4 on: June 25, 2014, 06:27:22 AM »
32gpm?
32 gpm !!!, you would be looking at something like 2" pipe. I want to say that 1.5" maxes out at something like 20-25 gpm.
Re: new install
« Reply #5 on: July 02, 2014, 10:38:55 AM »
Please forgive my ignorance Sprinter but.... is it even worth it (in terms of electricity savings) to use multiple 3-speed pumps for loops and controlled zones?  Return-on investment time might not be worth it but I did want to ask.  Thank you.  Cheers!
userdk
  • OWF Brand: Heatmaster SS
  • OWF Model: G 400
Re: new install
« Reply #6 on: July 09, 2014, 01:56:33 PM »
If you decide you can or you can't you're absolutely right. I don't know who devised that quote but it's absolutely right.
They can each do it with a different amount of pumps. Good luck to you and whoever you hire!!
